1" sensor superzoom
bajamiguel
April 22, 2023
chat_bubble_outline 10
    bajamiguel
    Members 3 posts
    April 22, 2023, 10:33 p.m. April 22, 2023, 10:33 p.m.
    I know of the sony RX10 series any others that you might know of with 600mm FF equivalent minimum length.
    ChrisRUK
    Members 28 posts
    April 22, 2023, 11:09 p.m. April 22, 2023, 11:09 p.m.
    Canon G3X goes to 600mm equivalent. The Panasonic LX1000 MkII only goes to 400mm equivalent.
    Nikon made a range of 1" interchangeable lens camera called the Nikon 1 Series. You could look for a used Nikon J5 with a Nikon CX 70-300mm lens. Otherwise, you need to look at larger sensor Micro 4/3 or smaller sensor fixed lens superzooms.
    LastPhoenix
    Members 15 posts
    April 22, 2023, 11:10 p.m. April 22, 2023, 11:10 p.m.
    Panasonic FZ1000 mark I/II - 1" sensor 400mm equivalent. Panasonic FZ2500 - 1" sensor 480mm equivalent.
    Canon G3 X - 1" sensor 600mm equivalent.
    LastPhoenix
    Members 15 posts
    April 22, 2023, 11:18 p.m. April 22, 2023, 11:18 p.m.
    @ChrisRUK has written:
    You have been a little bit faster.
    Nikon 1 + 70-300mm it's very compact camera with 300 * 5 == 1500mm FF eqv.
    Micro 4/3 often has 300mm it's only 600mm FF eqv, or 400mm it's 800mm. Also, I know that exists some convertors for leans.
    shermlevine
    Members 143 posts
    April 22, 2023, 11:25 p.m. April 22, 2023, 11:25 p.m.
    Within the Panasonic/Sony/Nikon small sensor forums I don't recall seeing anybody refer to the G3X (although cross-brand discussions within each group are quite common). I know it's a bit old (2015) but it's quite inexpensive compared to the other 1" superzooms. Is there a problem with it?
    Thank you
    Sherm
    bajamiguel
    Members 3 posts
    April 23, 2023, 6:50 p.m. April 23, 2023, 6:50 p.m.
    thanks everyone, already have em 10 with the 75/300. along with several other lenses. wife not happy with the weight of that kit as she wishes to go with carry-on luggage only. will check the used section at kerrisdale camera in vancouver.
    LastPhoenix likes this.
    LastPhoenix
    Members 15 posts
    April 23, 2023, 9:44 p.m. April 23, 2023, 9:44 p.m.
    Why do you not watch on 1"/2.33 superzooms? It steels enough for the publish on the internet. And they have the biggest optical zoom more than 1" superzooms.
    If you want to make shoots on a day it's not bad quality.
    Have a good vacation.
    ChrisRUK
    Members 28 posts
    April 25, 2023, 11:32 a.m. April 25, 2023, 11:32 a.m.
    @LastPhoenix has written:
    I think that you will find that 1" sensors have a 2.7x crop factor, so 300mm on the Nikon 1 is equivalent to 810mm FF.
    pwilly
    Members 26 posts
    April 25, 2023, 12:27 p.m. April 25, 2023, 12:27 p.m.
    I use my 300 f/4 f-mount on my Nikon 1 V1 once in a while. Same angle of view as 810mm is a LOT of reach, f/10.8 is rather slow. On a tripod it's good. It is much lighter than the D700 with the 300.
    JacquesCornell
    Members 45 posts
    May 1, 2023, 5:54 p.m. May 1, 2023, 5:54 p.m.
    It doesn't have a "1-inch" sensor, but...
    Panasonic FZ300:
    25-600mm EFL, constant max f2.8 aperture, weather sealed, 12MP 1/1.7" sensor. $500 new.
    Maxmolly
    Members 63 posts
    May 1, 2023, 8:10 p.m. May 1, 2023, 8:10 p.m.
    Yes, the G3X is not as sharp as the Sony RX10IV and in RAW the frame rate is 1 shot per second.
    AF is worse,too.
