32 inch softbox
Terryk1
April 26, 2023
chat_bubble_outline 19
    Terryk1
    Members 140 posts
    April 26, 2023, 9:21 p.m. April 26, 2023, 9:21 p.m.
    Hello,
    Is a 200 watt off camera strobe powerful enough to use a 32 inch umbrella type of softbox? Thank you.
    Terry
    DonaldB
    Members 2634 posts
    April 26, 2023, 9:23 p.m. April 26, 2023, 9:23 p.m.
    @Terryk1 has written:
    Hello,
    Terry
    Yes, its a good all round configuration.
    XRay
    Members 159 posts
    April 26, 2023, 9:34 p.m. April 26, 2023, 9:34 p.m.
    Hello,
    Terry
    For most situations, absolutely. And if that's not enough light for a particular aperture, move the umbrella/softbox in closer.
    Or simply bump ISO to 200. And before some of you act like you just witnessed a violent murder, just stop. You could shoot at 400 ISO all day long. No one would ever know.
    Terryk1 and DMCO like this.
    Terryk1
    Members 140 posts
    April 26, 2023, 10:04 p.m. April 26, 2023, 10:04 p.m.
    Thank you Don.
    Terryk1
    Members 140 posts
    April 26, 2023, 10:06 p.m. April 26, 2023, 10:06 p.m.
    Thank you Ray.
    XRay likes this.
    Terryk1
    Members 140 posts
    April 26, 2023, 10:37 p.m. April 26, 2023, 10:37 p.m.
    @XRay has written:
    Hello,
    Terry
    Terryk1
    Members 140 posts
    April 26, 2023, 10:39 p.m. April 26, 2023, 10:39 p.m.
    Should I use a 7” standard reflector too? I’m using the Neewer Q3 off camera strobe.
    DonaldB
    Members 2634 posts
    April 26, 2023, 10:47 p.m. April 26, 2023, 10:47 p.m.
    only unless you can use your strobe with bare bulb
    XRay
    Members 159 posts
    April 27, 2023, 12:31 a.m. April 27, 2023, 12:31 a.m.
    Exactly which 7" reflector are you referring to? Do you have a link?
    XRay
    Members 159 posts
    April 27, 2023, 12:33 a.m. April 27, 2023, 12:33 a.m.
    @DonaldB has written:
    The Q3 doesn't have a bare bulb option. It has a fixed fresnel head... unless you popped off the fresnel lens. But then the bare flash tube would still be shrouded.
    DMCO
    Members 244 posts
    April 27, 2023, 12:41 a.m. April 27, 2023, 12:41 a.m.
    The answers above are all correct for many ambient light conditions. That combo will work just fine. As said, if you need a bit more light, try to move the speed light towards your model a bit…. It will soften the light and make the model brighter.
    I will add a twist though…..
    Are you trying to overpower the sun? I.e are you trying to turn daylight into darkness…. Shooting at 2pm into the sun with your model’s back to the sun and he/she facing you? If so, then, most likely “no” that light and soft box won’t do that. There are limits. BUT, even in these conditions, it would make a nice fill light as you balance ambient and flash in your image.
    Terryk1
    Members 140 posts
    April 27, 2023, 2:27 a.m. April 27, 2023, 2:27 a.m.
    It’s just the standard one. 7” and they are all the same.
    Terryk1
    Members 140 posts
    April 27, 2023, 2:37 a.m. April 27, 2023, 2:37 a.m.
    All indoors. Thank you for all of your advice.
    Terryk1
    Members 140 posts
    April 27, 2023, 2:43 a.m. April 27, 2023, 2:43 a.m.
    @DMCO has written:
    Terryk1
    Members 140 posts
    April 27, 2023, 2:55 a.m. April 27, 2023, 2:55 a.m.
    There is a round bracket that holds the strobe and also has the slots for Bowens attachments. I watched YouTubes comparing the Q3 and AD200 as well as read reviews. I think the Q3 will serve me well, so I ordered a second one.
    Terryk1
    Members 140 posts
    April 27, 2023, 3:34 a.m. April 27, 2023, 3:34 a.m.
    Terryk1
    Members 140 posts
    April 27, 2023, 3:39 a.m. April 27, 2023, 3:39 a.m.
    I can use the 7” reflector with a sock as my main diffuser, can’t I? Why do I need a bare bulb in other cases?
    DonaldB
    Members 2634 posts
    April 27, 2023, 4:02 a.m. April 27, 2023, 4:02 a.m.
    yes i use one with my speed lights and its great for event work.
    Terryk1 likes this.
    Terryk1
    Members 140 posts
    April 27, 2023, 11:32 a.m. April 27, 2023, 11:32 a.m.
    All of you have been so helpful. I really appreciate it.
    DMCO likes this.
    Terryk1
    Members 140 posts
    April 29, 2023, 2:42 p.m. April 29, 2023, 2:42 p.m.
    It sounds like I should have bought 400 watt strobes.
