• Members 4 posts
    April 1, 2023, 8:57 p.m.
    Would it be possible to include exif info for images (assuming poster hasn't stripped it from his/her images)? I am sure others besides me would find this a useful inclusion.
  • April 2, 2023, 9:49 a.m.
    This has been asked for before and is on our list. Meanwhile,if you read this post dprevived.com/t/how-to-show-exif-data-in-chrome-firefox/501/ it shows you how you can do it for now with most common browsers.
  • April 2, 2023, 12:03 p.m.
    exif will come in future release.
    we can discus the values need meanwhile.
    my takes :
    • Brand
    • Model
    • Focual length
    • Shutter speed
    • Apature
    • Iso
    • Date
    • Geo Position (if available in the image and allowed by the user)
  • Members 44 posts
    April 3, 2023, 10:26 a.m.
    Great idea 43review. This would be amazing.
  • April 3, 2023, 11:02 a.m.
    Can we add
    Lens Type
    Metering mode
    Flash mode (if flash is taken)
    Exposure bias
    Thanks
  • Members 1846 posts
    April 3, 2023, 2:15 p.m.
    As a workaround, I am able to copy my EXIF data via IrfanView (free photo software) to the clipboard. From the clipboard I copy & paste the EXIF data to MS Word. Then to extract the lines I want I use this VBA code. Then I can copy & paste that into a DPRevived post (that would be the six lines). I don't copy & paste the first line (number 1) because that is just the filename which helps identify it.
    Sub EXIFData()
    Dim A As Integer
    Dim vardata
    vardata = Array(1, 3, 13, 14, 16, 27, 47)
    For A = 0 To 6
    ActiveDocument.Paragraphs(vardata(A)).Range.Copy
    Set myRange = ActiveDocument.Range _ (Start:=ActiveDocument.Content.End - 1, _ End:=ActiveDocument.Content.End - 1)
    myRange.Paste
    Next A
    End Sub
    I also wrote additional code to be able to do this quickly with multiple sets of EXIF data. I wrote more about it on the Canon APS-C forum under "Photo Test" if you are interested.
    I don't know if there's more "workarounds" but that is what worked for me. There's probably dozens of different ways. If anyone can share their ideas, that would be great.
  • Members 2 posts
    April 3, 2023, 2:45 p.m.
    All this can probably be done just by dragging the image to a shortcut running a simple EXIFTOOL command.
    April 3, 2023, 4:20 p.m.
    Can you elaborate? What do you mean by dragging an image to a shortcut? What is the shortcut? What is the simple EXIFTOOL command? Can you develop something and test it and give us details as I have done? What software would we use to accomplish that? For me, it was because I was using IrfanView (free photo software) and I had MS Word. The combination made it easy. But I'm not familiar with what you describe. I find it interesting and like to know what others do. There's always another way. :-) Thanks.
  • Members 16 posts
    April 3, 2023, 4:29 p.m.
    These are also good suggested additions to 43reviews list. Another suggestion is to add names of the software(s) used to post-process an image.
    Cathy
    April 3, 2023, 4:45 p.m.
    Once the photo is "open", I'm able to use sharesheet of an iPhone/iPad to read the EXIF. I used ViewExif, but all of the EXIF utilities I have installed are available.
    April 3, 2023, 4:51 p.m.
    Thanks. So what you are seeing might be similar to what I see in IrfanView (which is the extensive EXIF data). As a "workaround" how are you able to copy & paste it next to your image when posting it here on DPRevived? Or are you manually typing it in?
    April 3, 2023, 4:55 p.m.
    I don't as a matter of practice share that data here (unless relevant) but it's available for you to look at. I do have an iOS Shortcut (rough, but servicable) that I created that formats and copies some of the EXIF data to the clipboard so that it can be pasted.
    April 3, 2023, 5:18 p.m.
    Oh, I see...it's a custom program that you made. Yes, with MS Word VBA code I was able to select the EXIF data lines 1, 3, 13, 14, 16, 27, and 47 and put it at the bottom of the MS Word document. I was just sharing my code for everyone because sometimes people could find it useful or give them ideas with their own software. I could select other lines of data too. I just picked those ones that are important to me. I tested it with three and five images and it worked very well. Soon, DPRevived may fix this, but meanwhile we have our "workarounds".
