        • camera Wildlife
Any suggestions about low ligth manual/auto focus
43review
April 13, 2023
chat_bubble_outline 4
    43review
    Team 234 posts
    April 13, 2023, 7:34 a.m. April 13, 2023, 7:34 a.m.
    Doing some night shots with Z7 20mm
    dprevived.com/t/a-little-nightshift-with-z7-20mm-18/1747/
    My work-flow:
    • set AF to AF-S
    • focus on far away light or for near objects use flashlight to assist AF.
    • set AF to manual
    Take multiple photos.
    Now my problem is the huge manual focus ring of the 20mm.
    In the dark I touch it too often and focus is gone.
    Any Idea how to complete disable focus even manual AF?
    ReneGR
    Members 50 posts
    April 13, 2023, 6 p.m. April 13, 2023, 6 p.m.
    The only idea I have is to disable the focus ring in the settings. Don't know if that is possible with this lens. You can define a user mode for this. But it is an awkward solution.
    leitz
    Members 177 posts
    April 14, 2023, 7:46 p.m. April 14, 2023, 7:46 p.m.
    @43review has written:
    My work-flow:
    • set AF to AF-S
    • set AF to manual
    Now my problem is the huge manual focus ring of the 20mm.In the dark I touch it too often and focus is gone.
    Hope there's something useful here:
    www.google.com/search?q=nikon+20mm+z+lens+disable+focus+ring%3F&rlz=1C1SQJL_enUS873US873&ei=dqc5ZJfqKcDmkPIPnMmFoAk&ved=0ahUKEwiX_arci6r-AhVAM0QIHZxkAZQQ4dUDCA8&oq=nikon+20mm+z+lens+disable+focus+ring%3F&gs_lcp=Cgxnd3Mtd2l6LXNlcnAQDDIFCCEQoAEyBQghEKABMgUIIRCgATIFCCEQoAEyBQghEKABOgoIABBHENYEELADOg0IABBHENYEELADEIsDOgUIABCABDoGCAAQFhAeOggIABCKBRCGAzoFCCEQqwI6CAghEBYQHhAdOgoIIRAWEB4QDxAdSgQIQRgAUPQQWLJ2YM3DAWgBcAF4AIABsAKIAc4QkgEIMTMuNi4wLjGYAQCgAQHIAQe4AQLAAQE&sclient=gws-wiz-serp
    43review
    Team 234 posts
    April 14, 2023, 9:05 p.m. April 14, 2023, 9:05 p.m.
    Thanks to everybody.
    Deactivating in the menu A13 seems to depend on the used lens.
    Found this works for me with every lens:
    • menu f2 set af-on button to af-on activate focus
    • menu a7 set to only af.on button
    • set focus to af-s
    now focus ring will only work if i switch from af-s to manual.
    af works hitting af-on
    and shutter does not activate af.
    ReneGR
    Members 50 posts
    April 15, 2023, 7:30 a.m. April 15, 2023, 7:30 a.m.
    Seems to depend on the lens. I am using back button focus too. But manual override works on my lenses still, even if I do not press AF-ON. I won't see the focus peaking which works only while actually focussing. But the focus changes.
    I was already considering to suggest your solution before I posted mine. Then I tried it out, and it did not work.
