    April 10, 2023, 8:12 a.m.
    This article was posted on Preview.com on June 7, 2014, nearly 10 years ago. I believe this article is an interesting one and may be useful to people here.
    Can we have a super telephoto lens without using a lens? Of course, we cannot. Therefore, there has to be a lens in front of the camera but it is not an expensive camera lens.
    We will use a close-up lens but we don't do close-up shots. Here is what you need.
    • You will need a close-up lens. Use an achromat (i.e., 2 elements in 1 group). This post uses a Canon 77mm 500D.
    • Several extension tubes.
    • A bellows. This post uses a Nikon PB-6; but, you could use whatever bland as long as you are able to convert the bayonet mount to a thread.
    • Nikon has a K-2 ring that can just convert the Nikon F-mount to a female 52mm thread.
    • A camera, of course, that can fit your bellows and your extension tubes. I chose a Sony NEX5 because this camera can be adapted to virtually all brands and because its peaking and magnification MF aids are very good. In order to mount this Sony NEX5 to the Nikon F-mount, I used a Nikon F to Sony NEX adapter.
    • Some step rings.
    • That is it!
    The following image shows the tubes and adapter.
    www.cs.mtu.edu/~shene/FORUM/Taiwan-Forum/Random-Talk/005-DIY-500mm-Lens/LENS-Tubes-600.jpg
    The following is the Nikon K-2 ring. It converts a female 52mm thread to the Nikon F-mount.
    www.cs.mtu.edu/~shene/FORUM/Taiwan-Forum/Random-Talk/005-DIY-500mm-Lens/LENS-Nikon-K2.jpg
    Since we have a 52mm female thread, various step-up rings are needed to increase the thread size to a female 77mm thread (left below). Then, put the K-2 to the end and we have our 500mm lens head (right below).
    www.cs.mtu.edu/~shene/FORUM/Taiwan-Forum/Random-Talk/005-DIY-500mm-Lens/LENS-Head-Section.jpg
    Put all stuff on the PB-6 and we have the following. Note that to balance the weight of the bellows system being used, extension tubes are used at both ends of the PB-6 bellows.
    www.cs.mtu.edu/~shene/FORUM/Taiwan-Forum/Random-Talk/005-DIY-500mm-Lens/LENS-set-wo-camera-600.jpg
    Put my Sony NEX5 at the end and we are ready to go:
    www.cs.mtu.edu/~shene/FORUM/Taiwan-Forum/Random-Talk/005-DIY-500mm-Lens/LENS-500mm-CUP-600.jpg
    How do I know this is a 500mm telephoto? Good question.
    Although not every lens maker tells the power of a close-up lens, most makers show this information using diopter. The diopter of a close-up lens is defined as follows:
    diopter D = 1000/focal-length
    Thus, if you have a +2 diopter close-up lens, it has a focal length of 1000/2 = 500mm. If you don't know the diopter, you could do some tests to find it out and we won't discuss here. The Canon 500D has a focal length of 500mm (hence 500D).
    What is the maximum aperture of this setup? Another good question.
    It is about f/10. Hey, you may want to say that since the diameter of the Canon 500D is 77mm, the maximum aperture should be approximately 500mm/77mm = f/6.5. No, the Nikon compatible tubes all have a thread size of 52mm (see the above setup), and these tube act as the diaphragm of the lens (i.e., only the 52mm of the 77mm of the lens is used). This means the maximum aperture is 500/52 = f/9.6. Can we take the advantage of the full size aperture of 77mm? Yes, we can, but we will need a very long tube of 77mm in front of the bellows. This is currently impossible to do for me.
    What is the minimum length of the setup?
    Since the lens has a focal length of 500mm, the minimum length of the whole setup is at least 500mm for the lens to focus at infinity. When focusing to a closer distance, use the bellows to focus and the the whole setup extends. Therefore, to focus to a very close distance you will need a very long setup. For example, if you wish to do a 1:1 close-up shot, the image distance (i.e., the distance from the lens to the image sensor) is twice of the focal length. In our case, this setup must be able to extend to 500*2 = 1000mm! Those who played or are playing large format cameras know what I mean.
    Now let us take a look at the image quality of this setup.
    The distance from this bridge to the camera position is nearly 1km. The second image shows a 100% crop of the center area used for focusing.
    www.cs.mtu.edu/~shene/FORUM/Taiwan-Forum/Random-Talk/005-DIY-500mm-Lens/BRIDGE-CUP-600.jpg
    www.cs.mtu.edu/~shene/FORUM/Taiwan-Forum/Random-Talk/005-DIY-500mm-Lens/BRIDGE-CUP-C.jpg
    This is a scene a bit closer, perhaps around 600m. The second image shows the focusing area and the two tags of the left most two vehicle.
    www.cs.mtu.edu/~shene/FORUM/Taiwan-Forum/Random-Talk/005-DIY-500mm-Lens/CLUB-CUP-600.jpg
    www.cs.mtu.edu/~shene/FORUM/Taiwan-Forum/Random-Talk/005-DIY-500mm-Lens/CLUB-CUP-Crop.jpg
    This scene is about 50+ meters from the shooting position. The second and third image below show the center focusing area and the chains near the top edge.
    www.cs.mtu.edu/~shene/FORUM/Taiwan-Forum/Random-Talk/005-DIY-500mm-Lens/MAILBOX-50mm-CUP-600.jpg
    www.cs.mtu.edu/~shene/FORUM/Taiwan-Forum/Random-Talk/005-DIY-500mm-Lens/MAILBOX-50mm-CUP-C.jpg
    www.cs.mtu.edu/~shene/FORUM/Taiwan-Forum/Random-Talk/005-DIY-500mm-Lens/MAILBOX-50mm-CUP-T.jpg
    Now let us get closer, about 40+ m. Not so bad. Isn't it?
    www.cs.mtu.edu/~shene/FORUM/Taiwan-Forum/Random-Talk/005-DIY-500mm-Lens/LAMP-500mm-CUP-600.jpg
    www.cs.mtu.edu/~shene/FORUM/Taiwan-Forum/Random-Talk/005-DIY-500mm-Lens/LAMP-500-CUP-C.jpg
    This is a 30+m scene.
    www.cs.mtu.edu/~shene/FORUM/Taiwan-Forum/Random-Talk/005-DIY-500mm-Lens/CAR-CUP-600.jpg
    www.cs.mtu.edu/~shene/FORUM/Taiwan-Forum/Random-Talk/005-DIY-500mm-Lens/CAR-CUP-C.jpg
    This is a 20+ m scene. Please look at how this Canon 500D resolves the details.
    www.cs.mtu.edu/~shene/FORUM/Taiwan-Forum/Random-Talk/005-DIY-500mm-Lens/TRUNK-500mm-CUP-600.jpg
    www.cs.mtu.edu/~shene/FORUM/Taiwan-Forum/Random-Talk/005-DIY-500mm-Lens/TRUNK-500mm-CUP-C.jpg
    The following image was shot at a distance about 10m.
    www.cs.mtu.edu/~shene/FORUM/Taiwan-Forum/Random-Talk/005-DIY-500mm-Lens/METER-CUP-600.jpg
    www.cs.mtu.edu/~shene/FORUM/Taiwan-Forum/Random-Talk/005-DIY-500mm-Lens/METER-CUP-C.jpg
    It does not make much sense if this setup is not used to shoot birds. Well, BIF is a mission impossible with thisheavy setup and its slow focusing mechanism. But, I managed to get one bird shot as shown below.
    www.cs.mtu.edu/~shene/FORUM/Taiwan-Forum/Random-Talk/005-DIY-500mm-Lens/GULL-CUP-600.jpg
    www.cs.mtu.edu/~shene/FORUM/Taiwan-Forum/Random-Talk/005-DIY-500mm-Lens/GULL-CUP-B.jpg
    EPILOGUE
    This is not a new idea. The first camera in 1839 used essentially the same setup. Before WWI and right after it lens makers used this idea to design long focal length lenses. The following are some 2E/1G long focal length lenses. Just a final note. Do not use single element close-up lens. Otherwise, you will feel sorry for your decision. More details will be posted elsewhere and will be updated in the future.
    Enjoy!
    Carl Zeiss Jena Fernobjektiv 500mm f/8
    www.cs.mtu.edu/~shene/FORUM/Taiwan-Forum/Random-Talk/005-DIY-500mm-Lens/LENS-CZJ-Fernobjektiv-500-f8-D7000-600.jpg
    Asahi/Pentax Takumar 500mm f/5
    www.cs.mtu.edu/~shene/FORUM/Taiwan-Forum/Random-Talk/005-DIY-500mm-Lens/LENS-Pentax-500-f5-D7000-600.jpg
    Novoflex Novlexar 400 f5.6
    www.cs.mtu.edu/~shene/FORUM/Taiwan-Forum/Random-Talk/005-DIY-500mm-Lens/NEX5-Novoflex-Novlexar-400-f56-600.jpg
    Added Today (April 10, 2023, the day DPreview.com says Goodbye to us
    No one can avoid shooting the moon with a 500mm lens. Here is my attempt. The second image was a 1200x1200 crop and then resized to 600x600. Exposure was corrected slightly followed by a weak sharpening to reduce a touch of thin cloud covering a portion of the moon.
    www.cs.mtu.edu/~shene/FORUM/Taiwan-Forum/Random-Talk/005-DIY-500mm-Lens/IMG-CUP-Cloudy-Moon-600.jpg
    www.cs.mtu.edu/~shene/FORUM/Taiwan-Forum/Random-Talk/005-DIY-500mm-Lens/IMG-CUP-Cloudy-Moon-600-X.jpg
    A full version of this article (in Chinese) was published on June 15, 2014 and its translation by Google is available here. You will find more technical information and examples near the end of this article.
    Hope you like this post.
    Starting with tomorrow the world of photography will miss a great site and hope DPrevived will improve as soon as possible.
    CK
  • Members 122 posts
    April 10, 2023, 4:33 p.m.
    Sir,
    Most interesting adventure, the results look good enough to be mistaken for snaps from a recent auto-everything long focal lenght device.
    p.
  • edit
    Thread title has been changed from CK's Lens Post: Build a Super Telephoto Lenses w/o Using a Camera Lens.
  • Members 208 posts
    April 11, 2023, 12:50 p.m.
    Nice to see the results of this approach Chris.
    Technically it's a long focal length lens but not a telephoto (which technically is a lens shorter than its focal length), but no-one sticks to the technical definition anymore.
    Have you tried swapping the Canon 500D for a cheap (non achromatic) +2 lens? It would be interesting to see how they compare and might stop a few people being disappointed.
    April 11, 2023, 3:07 p.m.
    I know the difference between local focal length lenses and telephoto lenses; but, not all people care about this.
    No, I do not have any doublet +2 CUP lenses. What I can tell is that a singlet should not be used. I tried this and reported the results in my Chinese blog article, whose link was provided at the end of my post.
    CK
  • Members 208 posts
    April 11, 2023, 3:26 p.m.
    Thanks Chris, It does indeed look considerably worse, having a distinct soft focus type glow. I was expecting to see loads of CA too, but it wasn't noticeable with that subject.
  • Members 48 posts
    April 11, 2023, 3:32 p.m.
    I've used this technique on a 5"x4" Speed graphic camera , making use of it's focal plane shutter .
    Both using the lens at full aperture , and again raised forward on an extension tube with a Waterhouse stop in it to reduce the aperture .
    No maths involved working out where best to put the aperture , I just put it about an inch back .
    Shots from both setup's worked well .
    I keep meaning to try this on my medium format Kiev 88, I just need to fix a rear lens cap for some bellows onto a body cap off the Kiev to fix them together.
    I've a bellows for my Bronica ETRSi I can adapt to avoid vignetting that I might get using 35mm bellows .
