    April 6, 2023, 12:07 p.m.
    The first modern SLR appeared in East Germany, the Zeiss Ikon Contax S, around 1949. This is the camera that started the M42x1 lens thread. Note that even though M42 is frequently referred to as Pentax screw mount, M42 is not the work of Pentax. In fact, Asahiflex appeared in 1952, which is Japan's first SLR; however, it did not use pentaprism and its thread size was M37x1. Some may suggest that the Italian Rectaflex was the first modern SLR. However, in terms of production numbers and patent, the Contax S was really the first.
    Contax S: The first modern SLR that started the M42 lens thread mount
    Zeiss Ikon in West Germany started making SLR in 1953. This is the Contaflex series of cameras. All cameras in this series used fixed lens (i.e., non-interchangeable). The first two in this series, Contaflex I and Contaflex II, accepted a front-mounting teleconverter. However, started with Contaflex III and Contaflex IV in 1956, all subsequent cameras in the series used a convertible design. If you played with large format lenses, you perhaps know what a convertible lens is.
    The following is a Contaflex III of 1953.
    Contaflex III (1956)
    From Contaflex III and on, all cameras used Tessar 50mm 1:2.8 lens. The lever marked with a red dot is used to remove the front end of the Tessar lens.
    pages.mtu.edu/~shene/Zeiss-Ikon-Contaflex-Pro-Tessar-11-Macro-Lens/LENS-03.jpg
    Push the red dot lever inward followed by a twist to remove the front part of the Tessar. Note from the following image that there is a glass element in front of the aperture mechanism. Therefore, the "removable" component is just a single glass element. This front part is interchangeable.
    pages.mtu.edu/~shene/Zeiss-Ikon-Contaflex-Pro-Tessar-11-Macro-Lens/LENS-04.jpg
    There are three front lenses available as shown below. Note that the aperture mechanism and the glass element in front of it are fixed. This is the so-called convertable lens concept, because by swapping a portion of a lens we can produce multiple lenses. Note that a real convertible lens may allow both parts to be swapped.
    From left to right: Pro-Tessar M 1:1, Pro-Tessar 35mm f/4, Tessar 50mm f/2.8 (on camera lens), and Pro-Tessar 85mm f/4
    In his post, I tried the Pro-Tessar M 1:1 as shown in the left of the image below. The Pro-Tessar can reach 1:1 magnification.
    Left: Pro-Tessar M 1:1 Right: Tessar 50mm 1:2.8
    More than a year ago I bought a Contaflex lens and NEX adapter combo. The following shows the lens and the adapter, but the front end is a Pro-Tessar M 1:1.
    Contaflex with Pro-Tessar M 1:1 on a Sony A7II
    The maker of this lens and adapter combo was not very careful in choosing the lens, because the surface of the rear part of the lens has some cleaning mark that cannot be removed. By the way, this lens is very likely a lens salvaged from a Contaflex III, Contaflex IV or Contaflex Rapid. That is, this is a lens from the old series rather than a lens from a Super or a later model. The later lenses are supposed to be better.
    pages.mtu.edu/~shene/Zeiss-Ikon-Contaflex-Pro-Tessar-11-Macro-Lens/LENS-08.jpg
    The following image was taken with Pro-Tessar M 1:1 at nearly the minimum focus distance. It is clear that the vertical direction recorded approximately 22mm, which suggests that the magnification can be slightly higher than 1:1.
    Magnification at nearly minimum focus distance
    The following has some images. Refer to full size images to examine the quality of Pro-Tessar M 1:1. Note that, except for the first image, I did not use any PP.
    Mellon - slightly adjusted using PS Level
    Contrast is bit low but easy to correct
    Peanut
    Light Bulb Label
    Cherry
    The same cherry from a different angle
    I do not have any conclusions yet because it is the very beginning in shooting with these Pro-Tessar lenses. Please do keep in mind that all of these lenses appeared before 1959, the year Canon (Canonflex) and Nikon (Nikon F) released their first SLR professional cameras. Zeiss Ikon also made the Contarex (Bullseye or Cyclops) available, the first Zeiss Ikon interchangeable professional camera.
    Canonflex: Canon's first SLR (1959)
    Contarex Bullseye/Cyclops with a Contarex 135mm 1:2.8 -- Sorry, this lens is dirty. It is just for my own record.
    This article was first published @ dpreview.com on July 22, 2017. I have not used this setup for several years because its use is not very convenient. So, I repost it here without updates.
    CK
    PS: I still failed to figure out a way to post full size images. It is odd that a photo site does not provide this feature. Moreover, the caption that I added to the image do not appear. Anyone knows what went wrong?
  • Members 103 posts
    April 6, 2023, 1:12 p.m.
  • Members 1792 posts
    April 6, 2023, 2:17 p.m.
    That's very interesting - thanks for posting! I find this image particularly impressive - very good detal and nice rendering as well.I've never seen that particular Pro-Tessar, but I would love to try it. I have an S-Tessar 75 mm, which is also quite a capable lens.
    I can't tell you how to embed images more effectively, but maybe there's an explanation in the link. I usually use flickr embeds and those seem to work fine. I can view your images in original size by left-clicking and opening in a new tab, but I agree that an option to automatically open them in a lightbox would be preferable. If there's no option for that already I'm sure it is under consideration and will be implemented though, as I'm sure many people will need something like that.
  • edit
    Thread title has been changed from Zeiss Ikon Contaflex Pro Tessar 1:1 Macro Lens.
