Cropping — how do you do it?
davidwien
Dec. 27, 2024
chat_bubble_outline 36
    davidwien
    Team 2074 posts
    Dec. 27, 2024, 10:41 a.m. Dec. 27, 2024, 10:41 a.m.
    I always save raw files as 3 x 2 format in camera. But after processing they rarely end up with that aspect ratio. Usually, I crop quite freely until what I dont want around the edges has been removed. Very occasionally, I may deliberately end up with a 1:1 file, but generally I dont care about the numerical value of the aspect ratio.
    What do others do?
    Forum Admin 4232 posts
    Dec. 27, 2024, 10:59 a.m. Dec. 27, 2024, 10:59 a.m.
    I'm the same as you. I don't care about aspect ratios - unless I am printing. Then, I do.
    Photobygms
    Members 1077 posts
    Dec. 27, 2024, 11:36 a.m. Dec. 27, 2024, 11:36 a.m.
    I almost all the time crop with keeping the original aspect ratio (3-2 for 10x15 cm, 4x6 inch printing)
    davidwien
    Team 2074 posts
    Dec. 27, 2024, 11:48 a.m. Dec. 27, 2024, 11:48 a.m.
    I suppose the point is that I hardly ever print anything on to paper. If I did, I would probably crop the print also! (It seems strange to me to restrict the aspect ratio to what is available commercially!)
    NCV
    Members 2760 posts
    Dec. 27, 2024, 1:44 p.m. Dec. 27, 2024, 1:44 p.m.
    As I tend to print or post pictures in a series of linked pictures, I generally crop to the original frame format, to keep the presentation coherent.
    ArvoJ
    Team 1306 posts
    Dec. 27, 2024, 2:13 p.m. Dec. 27, 2024, 2:13 p.m.
    If images are in series then I'm trying to keep original ratio - as far as that works; for single images ratio is not important. I do not print images.
    Rich42
    Members 1045 posts
    Dec. 27, 2024, 8:39 p.m. Dec. 27, 2024, 8:39 p.m.
    I crop according to the needs of the image. The camera’s “aspect ratio” is an irrelevant design reality, the result of engineering decisions necessary to manufacture the device. I have never understood the slavish attachment to particular format ratios which many hold as inviolable.
    There are only two kinds of images. Those that have been printed, and those that have yet to be.
    I print as large as possible.
    davidwien likes this.
    RonP
    Members 193 posts
    Dec. 27, 2024, 10:31 p.m. Dec. 27, 2024, 10:31 p.m.
    @davidwien has written:
    What do others do?
    The majority of mine are done in 16:9 as it simplifies viewing them on large screens and it's not too far from most phone sizing when I post something online. If a shot demands it, I will crop to suit and most likely this will be a custom fit or 1:1. Not much use for "fixed" ratios as an agenda. By and large, knowing I can go back and re-crop from the RAW anytime I like, means not really being fussed too much about "final" sizing.
    Ron
    xpatUSA
    Members 1593 posts
    Dec. 27, 2024, 10:35 p.m. Dec. 27, 2024, 10:35 p.m.
    Rich42 has written:
    My Panasonic Lumix LX1 is interesting with it's native 16:9 aspect ratio sensor. For other ratios, the actual raw data is cropped horizontally, none of which other rarios fit my WUXGA monitor.
    I do not print and I only view on my monitor (1920x1200 px), so any old aspect ratio is OK for me ... but ...
    ... could it be that some aspect ratios are "better" than others? (my monitor at 1:1.6 is pretty close to the Golden Ratio 😀 ).
    OT, but I wrote long ago about rectangular watch proportions which also have popular values:
    tcktek.blogspot.com/2009/11/rectangular-watch-proportions.html.
    davidwien
    Team 2074 posts
    Dec. 27, 2024, 10:57 p.m. Dec. 27, 2024, 10:57 p.m.
    I dont know about other cameras, but as far as my Canon EOS R6 and Leica Q3 are concerned, the selection of 16x9 for raw files means that the whole sensor, which is 3x2, is not used.
    xpatUSA
    Members 1593 posts
    Dec. 27, 2024, 11:20 p.m. Dec. 27, 2024, 11:20 p.m.
    Another interesting Panasonic is the Lumix DMC-GH1 which has an oversize µ4/3 sensor from which all raw images have the same diagonal pixel dimension.
    They call it "angle of view":
    At first sight this may seem strange but the result is that the lens offers the same diagonal angle of view regardless of selected aspect ratio, making it much easier to get a feel for the behaviour of the lens. It also means you make the most of the sensor area, getting similar pixel counts in all modes.
    www.dpreview.com/reviews/panasonicdmcgh1
    RonP
    Members 193 posts
    Dec. 28, 2024, 12:31 a.m. Dec. 28, 2024, 12:31 a.m.
    Why does that upset you ?
    Ron
    xpatUSA
    Members 1593 posts
    Dec. 28, 2024, 3:11 a.m. Dec. 28, 2024, 3:11 a.m.
    @RonP has written:
    Especially as any crop in post does the same thing effectively ...
    Bryan
    Members 1937 posts
    Dec. 28, 2024, 4:37 a.m. Dec. 28, 2024, 4:37 a.m.
    @xpatUSA has written:
    @RonP has written:
    Yes, but my ideological mind says get all you can out of the native format of the sensor and then crop as one wishes later.
    xpatUSA
    Members 1593 posts
    Dec. 28, 2024, 6:23 a.m. Dec. 28, 2024, 6:23 a.m.
    @Bryan has written:
    @RonP has written:
    ... the whole sensor, which is 3x2, is not used
    Oh. A bit vague, Bryan, sorry.
    davidwien
    Team 2074 posts
    Dec. 28, 2024, 7:12 a.m. Dec. 28, 2024, 7:12 a.m.
    @RonP has written:
    Ron
    Upset me? Not a bit.
    But it doesnt seem sensible to pay for n MP and not have them all available in the raw file. This is even truer if one were to start off with an image of 16x9 and crop to 3x2.
    Bryan
    Members 1937 posts
    Dec. 28, 2024, 7:19 a.m. Dec. 28, 2024, 7:19 a.m.
    @Bryan has written:
    @RonP has written:
    By using a non-native format you are losing some pixels along either pair of parallel edges.
    At capture / composition time you don't necessarily know how you are going to crop. Get your subject plus a bit more and adjust in pp.
    To get back to the OP, certainly the image determines the crop - I am not printing yet so that may impact decisions down the track.
    As my laptop monitor is 1366 x 768 (HD) I find myself tending to crop more towards 16:9 if the image allows.
    3DGunner likes this.
    3DGunner
    Members 480 posts
    Dec. 28, 2024, 9:03 a.m. Dec. 28, 2024, 9:03 a.m.
    @Bryan has written:
    I follow the same principle.
There are 19 more posts in this thread.
