      • General Articles
      • Governance and organisation
      • Updates & Bugs
      • Introduce yourself
  • label Site Site Discussions
  • label UB Updates & Bugs
Disappearing * character
JackHogan
May 1, 2023
chat_bubble_outline 30
    JackHogan
    Members 78 posts
    May 1, 2023, 2:48 p.m. May 1, 2023, 2:48 p.m.
    For instance this line has a number of multiplication (*) characters in it and looks fine when editing and in preview
    sqrt( QE^2p + QEp - QE^2p ) = sqrt( QEp )
    However, they are gone once published.
    Forum Admin 3301 posts
    May 1, 2023, 3:48 p.m. May 1, 2023, 3:48 p.m.
    3 * 6 = 18
    May 1, 2023, 3:50 p.m. May 1, 2023, 3:50 p.m.
    Can you put the correct formula between the quotes like this:
    Quoted message:
    3 * 6 = 18
    That should preserve them so I can see what's going on when I try and reproduce the issue.
    JackHogan
    Members 78 posts
    May 1, 2023, 4 p.m. May 1, 2023, 4 p.m.
    @JackHogan has written:
    Hi Alan, you should be able to see the original text if you click on 'edited x times' above.
    May 1, 2023, 4:03 p.m. May 1, 2023, 4:03 p.m.
    Yep - I get it too. I wonder what's going on. I will ask.
    JackHogan
    Members 78 posts
    @AlanSh has written:
    3 * 6 = 18
    Yes, introducing a space preserves the *
    lehill
    Members 75 posts
    May 1, 2023, 4:07 p.m. May 1, 2023, 4:07 p.m.
    To me, it looks like the " * " character is being used by the editor to turn italics on/off.
    @AlanSh has a nice clean method by using quote
    Code block and inline code works too but it's not as nice as using quote. Inline code: sqrt( QE^2*p + QE*p - QE^2*p ) = sqrt( QE*p )
    JackHogan likes this.
    May 1, 2023, 4:08 p.m. May 1, 2023, 4:08 p.m.
    Or you can put a space either side of the * character
    sqrt( QE^2 * p + QE * p - QE^2 * p ) = sqrt( QE * p )
    JackHogan and lehill like this.
    jaberg
    Members 535 posts
    May 1, 2023, 4:10 p.m. May 1, 2023, 4:10 p.m.
    * is a formatting character used by Markdown, which is a text-to-html formatting tool supported by our current editor.
    If I type *Hello* (asterix[nospace]Hello[nospace]asterix) I get Hello
    If I use spaces I get this * Hello *
    If you want to use an * inline, (as I did here, and above) you can precede it with the escape character \ (backslash)
    \*Hello\* (BackslashAsterix[nospace]Hello[nospace]BackslashAsterix) = *Hello*
    In my last example I also escape the backslash by preceding each of them with, you guessed it, another backslash.
    JackHogan, Deleted and lehill like this.
    May 1, 2023, 4:30 p.m. May 1, 2023, 4:30 p.m.
    I've done some tests here dprevived.com/t/testing-special-characters/2875/
    It's not a bug - it's a function of the editor we use.
    JackHogan
    Members 78 posts
    May 1, 2023, 4:35 p.m. May 1, 2023, 4:35 p.m.
    I figured as much. I think your quote suggestion is pretty good (+ the latex interpreter;-)
    JimKasson
    Members 1738 posts
    I had the same issue with CIELstarastarbstar, when the stars are replaced with asterisks.
    CIELab*
    Here it is with backslashes: CIEL*a*b*
    Deleted and JackHogan like this.
    AlainCh2
    Members 535 posts
    May 1, 2023, 6:12 p.m. May 1, 2023, 6:12 p.m.
    sqrt( QE^2\*p + QE\*p - QE^2\*p ) = sqrt( QE\*p )
    jaberg
    Members 535 posts
    May 1, 2023, 6:24 p.m. May 1, 2023, 6:24 p.m.
    Just don’t take my Markdown away! ;)
    StanDisbrow
    Members 510 posts
    May 1, 2023, 7:08 p.m. May 1, 2023, 7:08 p.m.
    Yes, the asterisk, also called the Splat character, is used before and after a word to be read as italic on a teletype. Yep. Paper terminals, which we used on computers before we had VDTs - Video Display Terminals. KSR-33, for example. Keyboard Send Receive model 33 that is.
    It's called the Splat, because it looks like a bug which has been hit with the typing unit of a TTY. A Splat on the paper, as it were. Sometimes they are bugs. And I just added splats before and after the word 'are' there.
    It translated over to the VDT quite well, even though later units had the capability to display italicized characters.
    So the editor, or rather the programmer of the editor, has been around long enough to know of this convention. ;)
    Next up: Did y'all know that the Fax has been around since the US Civil War? Yep. Used to send maps over telegraph lines! And still used for sending weather maps to small airports.
    Stan
    JimKasson
    Members 1738 posts
    May 1, 2023, 7:10 p.m. May 1, 2023, 7:10 p.m.
    @StanDisbrow has written:
    Also known as star, as in del *.* being pronounced "dell star dot star."
    StanDisbrow
    Members 510 posts
    May 1, 2023, 7:13 p.m. May 1, 2023, 7:13 p.m.
    Run that and there will be no files left! Not quite as bad as Format C: (!)
    Stan
    StanDisbrow
    Members 510 posts
    May 1, 2023, 7:15 p.m. May 1, 2023, 7:15 p.m.
    BTW, the first time I went and used splats, or stars, before and after a word and saw where it subbed italics, I had a good chuckle. :)
    Stan
There are 13 more posts in this thread.
