      • General Articles
      • Governance and organisation
      • Updates & Bugs
      • Introduce yourself
  • label Site Site Discussions
  • label UB Updates & Bugs
Forum updates 14th March 2025
chat_bubble_outline 29
    Forum Admin 3289 posts
    March 7, 2025, 4:19 p.m. March 7, 2025, 4:19 p.m.
    Sunday 9th March is when I plan to make changes to the forum structure. So, expect forums to appear and disappear and threads to move around.
    I'll post updates as things happen.
  • bookmark
    • By AlanSh on March 7, 2025, 4:19 p.m..
    March 8, 2025, 6:54 p.m. March 8, 2025, 6:54 p.m.
    The update may be delayed - we have found an issue with private messages which we cannot explain. So, I want to get that fixed first.
    I'll keep you updated.
    March 9, 2025, 1:09 p.m. March 9, 2025, 1:09 p.m.
    I've reserved the 14th and 15th March in my diary to get the updates done now. I'll update the title.
  • edit
    Thread title has been changed from Forum updates 9th March 2025.
    • By AlanSh on March 9, 2025, 1:09 p.m..
    March 13, 2025, 1:59 p.m. March 13, 2025, 1:59 p.m.
    Tomorrow - Friday (all being well), I will be creating new forums and moving threads around as per the plan published some time ago (dprevived.com/t/forum-updates-to-come-your-thoughts/7002/). So, be prepared for things to change as you look. And where you post something may not be where it ends up.
    Any issues, message me.
    March 14, 2025, 12:29 p.m. March 14, 2025, 12:29 p.m.
    IMPORTANT
    While I am moving threads around, you will find that the "Threads" menu item has lots of old posts in them. This is because moving threads updates the date last modified field. There is nothing I can do about this. lease be patient with me - it will all sort itself out in a few days as new threads/posts are written
    minniev likes this.
    Bryan
    Members 1431 posts
    March 14, 2025, 1:39 p.m. March 14, 2025, 1:39 p.m.
    @AlanSh has written:
    IMPORTANT
    Is it too late to reverse it? It has completely broken the chronological order of all the threads.
    ArvoJ
    Team 899 posts
    March 14, 2025, 1:41 p.m. March 14, 2025, 1:41 p.m.
    It is possible to fix that by removing admin notice about thread movement.
    March 14, 2025, 1:43 p.m. March 14, 2025, 1:43 p.m.
    Yes it's too late to go back. I can get it back by going into each post and deleting the text that says 'this thread was moved'. I'll look into doing that once we have finished. But that's hundreds of threads I have to fix
    Is there anything in particular you need fixing?
    Bryan
    Members 1431 posts
    @ArvoJ has written:
    That would be the easy fix - but would be better to be done by script otherwise rather laborious...
    March 14, 2025, 1:44 p.m. March 14, 2025, 1:44 p.m.
    @ArvoJ has written:
    Yes, that fixes it but I have to do them one at a time
    March 14, 2025, 1:45 p.m. March 14, 2025, 1:45 p.m.
    If you know a quick way, please let me know
    ArvoJ
    Team 899 posts
    March 14, 2025, 1:46 p.m. March 14, 2025, 1:46 p.m.
    I did that for editmeanimage threads - I have not much time at the moment :(
    /edit/ Did landscape too.
    Bryan
    Members 1431 posts
    March 14, 2025, 1:47 p.m. March 14, 2025, 1:47 p.m.
    @ArvoJ has written:
    From that I am assuming date of last post determines the chronological rank of the parent? Or is it possible the parent has a date field that is updated after a post?
    ArvoJ
    Team 899 posts
    March 14, 2025, 1:48 p.m. March 14, 2025, 1:48 p.m.
    @Bryan has written:
    @ArvoJ has written:
    So I am assuming date of last post determines the chronological rank of the parent? Or is it possible the parent has a date field that is updated after a post?
    Yes, date of the last post - see landscape and editmeanimage threads, should be in correct order now.
    Bryan
    Members 1431 posts
    March 14, 2025, 1:56 p.m. March 14, 2025, 1:56 p.m.
    If someone can create a script to do it at database level - but dangerous territory unless one knows what one is doing. A backup of the database always required first... And either a temporary lock on posting or some method of logging any posts while until settled and then add them.
    ArvoJ
    Team 899 posts
    March 14, 2025, 2:04 p.m. March 14, 2025, 2:04 p.m.
    Manually is easier. I did that for B&W threads now.
    /edit/ And C&C is fixed.
    March 14, 2025, 2:24 p.m. March 14, 2025, 2:24 p.m.
    Thanks, Arvo,
    I'll try and keep that up to date when I move threads. Deleting forums and moving threads is different and doesn't affect things.
    March 14, 2025, 2:34 p.m. March 14, 2025, 2:34 p.m.
    I'm doing weekly cats!
There are 12 more posts in this thread.
