• Members 1859 posts
    April 9, 2023, 11:58 a.m.
    I recently bought an FZ300 and noticed some posts from owners re lens cap falling off when hiking / moving around.
    I had found that sometimes the lens cap popped off but only when I had just put it on. I realised that the orientation of the spring tabs to the lens (up / down, left right, a few degrees this way or that way affected whether it would stay on.
    So today I had a closer look. You will see that the embossed edges at the end of the tabs are actually threads, albeit not much. So they will screw in. Playing with it I found where I could consistently get it to stay, and if it felt loose as I placed it, just a clockwise twist of about 10 or 15 degrees would lock it in....
  • Members 21 posts
    April 12, 2023, 12:34 p.m.
    I also use a lens-keeper lanyard so I don't lose the lens cap if/when it does come off. That also allows for a quick pop-and-drop of the lens cap when a sudden shot appears without worry of losing it or having to tuck it away somewhere.
