• Members 1204 posts
    Sept. 19, 2024, 1:21 a.m.
    It is interesting to look up the word audacity and go through the differing definitions. They all basically say the same thing though.
    Dan I really don't think it appropriate for you to take on a moderator type role and edit other people's posts. Especially crossing out their text, and especially because you are the first to whinge / shout when someone selectively quotes you...
    It is totally inappropriate!!!
    Sept. 19, 2024, 1:59 a.m.
    That is your opinion and that's fine. In any case you are not a moderator either, so practise what you preach if need to be taken seriously.
    I didn't change what Mike said. I fixed his post so that who said what is now accurate and clear.
    What is inappropriate is you telling blatant lies in other threads here claiming danhasleftforum uses multiple accounts on dpreview to rig the voting in dpreview challenges and then cowardly running away when asked to post evidence supporting your lies.
    If your false accusations were true you will be hard pressed to convince anyone you wouldn't post the evidence proving them in a heartbeat. Instead you run away every time holding your tail between your legs.
    Check the dumpster if your memory needs refreshing.
    If you telling lies about danhasleftforum is appropriate then clearly it is then also appropriate for anyone to post lies about NCV, who also tells lies about members he doesn't like, wherever they like.
    Again, check the dumpster if your memory needs refreshing.
    You can't have it both ways.
  • call_merge
    The Moved from C&C thread has been merged into this thread.
  • call_merge
    The Moved from CC thread has been merged into this thread.
