• Members 54 posts
    May 9, 2023, 9:54 p.m.
    An Airport Extreme uses an original way of cooling as the cooling air is sucked in
    at the bottom of the tower, passes the PSU going upward toward the top and
    then goes down the other side, passing all the electronics and the
    forest of cooling fins that you find there. Between the two you can install a
    hard drive that doesn't seem to have any cooling at all.
    Or maybe the air maybe goes the other way (I have not found any documentation
    showing if my guess is right or not)?!
    The fan (at the top) inside the little tower-like box died yesterday, squealing
    like a pig and then silence. Sadly, I found I didn't have some of the essential tools for
    getting the innards out, as getting access to the fan requires some fancy ones.
    So what to do?!
    After some thinking, I decided to ventilate the housing (the bottom was taken off already),
    by drilling seven 1/2" holes in the rear side of the tower and five holes in the right side
    of the tower, to improve the ventilation on the side with the electronics, and then
    put it face down to improve the circulation further (the bottom was not re-mounted
    to improve the passive airflow). There are no children or pets in the house,
    and there iare no bare wires at that end.
    Worked great!
    Just 55 C on the cooling fins surface (approx 130 F) after the drilling, not perfect but OK.
    A friend had a similar tower (not sure if it was an Airport) that one day had a similar failure,
    almost burning down his fantastic bungalow. But smoke damage was extensive. For instance,
    a lot of textiles in the house needed to be sent off to the cleaners or thrown away. The drive
    stood on top of a hefty glass table so the fire didn't spread much but the house needed a lot of
    repainting afterwards.
    Weeks later the house still smelled of smoke!
  • Members 45 posts
    May 10, 2023, 2:06 p.m.
    Good that you have your AirPort Extreme up and working again. Never thought about such a "solution" . Your post did however made me vacuum clean that bottom air inlet. I never ever did this, and my AirPort Extreme is sitting on carpet upstairs for years and years now (without any physical "maintenance" at all). There had to be quite some dust inside (hopefully removed now).
    No reason for any drastic action like drilling holes (yet, I think), but surely a warning to take care.
    Thank you!
  • Members 909 posts
    May 12, 2023, 1:54 p.m.
    The Airport Extreme has been discontinued for at least 5 years. When Apple release it - there was a need for an easy to set up WiFi router. By 2015 that need was disappearing. It was easy for anyone to set up an extended WiFi network with the Airport Extreme. Ten years ago - Apple was the only game in town for that. Today the modern Mesh devices of it for you. I replaced my extended Airport network when lightning came in on the cable, fried the Internet modem and the charge passed on through the modem and fired my master Airport Extreme. I replaced it with a eero6 Pro three device mesh and was back up in no time after I picked up a new modem from Spectrum. The Airport Extreme was a great device for its time but today there are a lot of other options.
