• Members 36 posts
    April 29, 2023, 8:57 a.m.
    I'm interested by a light travel-compatible tripod.
    I know the Peak Design travel carbon tripod from YT reviews and users, but I always fear a bit the over-enthusiastic honeymoon review, when it's not a blatant product placement/gift-for-review video.
    Hence here my question. Are there here users of this and is it working as intended and worth its already hefty price tag or is it more of a fashion/hipster/geek stuff?
    Mind you, I'm certainly not against form vs functionality (Sigma fp here, for landscape, architecture, and a bit of family/tourism too), and am also concerned by the look of my gear (an ugly gear to my eyes is a gear I don't want to use, regardless of its superior marginal qualities). For instance, Peak Design travel tripod is appealing, as is a Gitzo traveller serie 1, but for example, all three legged thing tripods are awfully gaudy blingy stuff for me. Ymmv of course, each her/his own beauty :-).
    Thank you for your feedback already,
    Greg
  • Members 607 posts
    April 29, 2023, 10:31 a.m.
    You don’t list to or tell us the model number!
    gregvds wrote: and am also concerned by the look of my gear (an ugly gear to my eyes is a gear I don't want to use, regardless of its superior marginal qualities). For instance, Peak Design travel tripod is appealing, as is a Gitzo traveller serie 1, but for example, all three legged thing tripods are awfully gaudy blingy stuff for me.
    Maybe photography is not for you. lol
    Seriously Greg.
    I would definitely recommend trying out tripods in a store before making a purchase.
    My camera buddy has five old tripods in his garage,
    I have one… a GITZO G 1325 MK2 a sturdy carbon-fiber tripod.
    When I purchased this back in 2003 it was around £600
    www.dpreview.com/forums/post/63123417
    Scott Dordick made me a ball-head in the same year.
    www.dpreview.com/reviews/mid-sized-ball-heads-tested/2
    L brackets and mounts from Really Right Stuff.
    April 29, 2023, 11:26 a.m.
    The Peak Design carbon fiber model is the tripod I use most often with my Fujifilm, MFT and mobile cameras. It mostly works as advertised. Very compact — can be packed inside my 15 L ruck when necessary. The tripod fits fits into external bottle pockets. Very fast to deploy and adjust. Extremely “dead” and stable for its size. I like Peak’s take on a ball head in use (for stills.) If I don’t mind sacrificing a bit of compact and light I can also install my Manfrotto pistol grip ballhead. (It weighs more than the legs.)
    Biggest downside: When using the standard head, I use a long Arca plate to adjust the balance point of my X-S10 and the (extended) 70-300. Basically an improvised lens foot. This is only necessary for locking the position of this combination to focus on a precise point — for example, on a nest. You can get the tripod to lock in place without, but you have to “aim high” and predict the drop. It’s not necessary if you’re using the tripod to support panning or tracking.
    Fujifilm X-S10 |FUJINON XF70-300mmF4-5.6 R LM w/ DIY “lens foot”. The lens isn’t extended here. The tripod would hold position even without the “foot”. As you zoom in, the field-of-view will begin to drop unless you move the mounting axis forward.
    An alternative is to use the (optional) adaptor to attach a burlier tripod head like that I mention above. I can mount my gimbal head to the PD legs too. That’s overkill for the 70-300 though and if I’m carrying the gimbal (and the Canon 500 FD) I generally just use full-sized Manfrotto legs.
    Canon FD 500 4.5L, Panasonic Lumix DMC-GX85, and Neewer gimbal on the carbon fiber Peak Design Travel Tripod legs. This loads the legs to the edge of their capacity — particularly on this uneven ground. If you look carefully you’ll notice a slight bow in the rearmost tripod leg.
    Other quibbles: In practice, you’ll want to use an L-bracket for portrait orientation. Having to swap between rubber feet and spikes is annoying. The onboard phone mount isn’t my favorite to use, but it is always available and does work. You may wish for more height at times, but then you will be glad it’s not there when it’s time to pack this away. This is a full featured travel tripod. Compact is a virtue.
    Disclosure: I was a member of PD’s “pro” program at the time of purchase and I did receive a significant discount. This made the cost easier to swallow. Having used the product since the very early days of its release I find value in it and, should it be lost or damaged, I would be very likely to replace it, even at full price.
    JPG, 837.5 KB, uploaded by jaberg on April 29, 2023.
    JPG, 647.7 KB, uploaded by jaberg on April 29, 2023.
    April 29, 2023, 11:40 a.m.
    There are only two Peak Design Travel Tripods. They are identical in design, function, and use. The difference is the base material: aluminum or carbon fiber. (And by extension the cost and weight.)
  • April 29, 2023, noon
    Peak design stuff is all of excellent (top) quality, but lists at top prices, too! I dont have the tripod, but I do have their cuff, about which I would make the same comments. I would say, if the price of the carbon tripod is not a problem, go for it...
  • Members 45 posts
    May 2, 2023, 6:38 p.m.
  • Members 71 posts
    May 2, 2023, 7:02 p.m.
    Another alternative that shouldn't go unmentioned is the Ulanzi Zero Y Lightweight Travel Tripod. I've got one and can wholeheartedly recommend it, though I can't offer a comparison to the PD TT.
  • Members 36 posts
    June 1, 2023, 3:53 p.m.
    In the end, I went for the Gitzo traveler Serie 1, 4 sections, and am really happy :-).
    Greg
  • Members 45 posts
    June 1, 2023, 6:15 p.m.
    Very good choice! Congratulations!
  • Members 8 posts
    June 16, 2023, 12:08 a.m.
    This small Arca-compatible pano clamp solves the biggest complaint about PD tripod - limited head articulation.
    My clamp is older and not sold anymore, this one is very similar: CAMVATE 360° Arca-Type Clamp:
    Overall, I am happy with PD carbon tripod. However, I ordered Heipi 3-in-1 tripod, will post a short review when I get it. I also ordered Benro CyanBird, but I am less optimistic about it's sturdiness - will update when I get it (maybe this weekend).
    JPG, 734.5 KB, uploaded by zodiacphoto on June 16, 2023.
