        • camera Wildlife
Question regarding A7RV 10FPS mechanical shutter
backbuttonfocus
April 10, 2023
chat_bubble_outline 3
    backbuttonfocus
    Members 1 post
    April 10, 2023, 7:12 a.m. April 10, 2023, 7:12 a.m.
    From the user manual, it stated that
    helpguide.sony.net/ilc/2230/v1/en/contents/TP0002911187.html has written:
    The subject is not displayed in real-time on the monitor or viewfinder when shooting in [Continuous Shooting: Hi+] mode.
    Does that mean that in order to see the subject in real-time (with blackout) during burst shooting, I have to use Continuous Shooting: H, which is 8FPS?
    Thanks in advance
    HatredTantrum
    Members 5 posts
    April 10, 2023, 1:39 p.m. April 10, 2023, 1:39 p.m.
    Check this VIDEO at 3:36, should be the same on RV, instead of actual blackout, you'll see a slideshow with a small delay to the actual movement. (you see a last taken frame, and blackout frames are technically hidden from the view)
    SQLGuy
    Members 35 posts
    April 10, 2023, 2 p.m. April 10, 2023, 2 p.m.
    @backbuttonfocus has written:
    Thanks in advance
    To see the subject in real time, with no blackout, you would need to use a stacked sensor camera (A9, A9II, or A1), and shoot with electronic shutter. Any mechanical second curtain will be covering the sensor during readout. And any non-stacked sensor will be unable to update the viewfinder during exposure.
    SilvanBromide
    Members 146 posts
    April 11, 2023, 6:31 a.m. April 11, 2023, 6:31 a.m.
    The 10fps (with blackout) is quite doable for most action shooting, though it does take a bit of practice to get the hang of tracking when there is a lag and flicker going on. Until recently, every camera had that issue, and people have just had to cope.
    That said, the stacked sensor cameras shooting in ES mode with no blackout are quite a different experience, and a joy to use after working past the limitations of mech shutter cameras.
