    June 19, 2023, 2:57 p.m.
    I edited while you were typing, Iliah, please see above. I used the quote marks because we were unable to find that exact phrase in the article; I was not intending to discuss it's meaning.
    June 19, 2023, 3:45 p.m.
    In proportion to the conductance. Or inversely proportional to the resistance. But you know that.
  • June 19, 2023, 4:06 p.m.
    Indeed, silly mistake.
    June 19, 2023, 4:18 p.m.
    no comment
  • Members 2632 posts
    June 19, 2023, 10:07 p.m.
    let me get this right ,you like using blinkies but they are not helpful 😏 other wise i like your overall post.
    June 19, 2023, 10:18 p.m.
    its been 40years since i studied/played electronics. it just works 😁 and i calibrate the meter without any mathematics ,pretty much the same as my photography.
  • Members 138 posts
    June 19, 2023, 10:19 p.m.
    Current implementations use the JPEG EVF image, not much use for determining clipping with all the processing applied. I want blinkies based on the raw data.
    June 19, 2023, 10:22 p.m.
    have you actually tested your histogram accuracy ? because my sony a74 coudnt be any more accurate.
    June 19, 2023, 10:29 p.m.
    "I determined it using the exposure triangle."
    Gold 😁
    June 19, 2023, 10:30 p.m.
    It's a histogram of a JPEG, and it's accurately histograms that JPEG :))
    June 19, 2023, 10:35 p.m.
    Scenes don't have brightness, they have a range of brightnesses. Otherwise they are as emotionally engaging as uniformly lit grey cards are.
    June 19, 2023, 11:01 p.m.
    Blinkies based on the raw data would be pretty cool, Glenn.
    That would be interesting to do, Donald, but sadly I don't know how to test the accuracy of my histogram.
    As you likely know, a histogram is a set of vertical columns arranged sid-by-side, each column width (or "bin") representing a range of values and each column height representing a count of how many image pixel values are within that range. The problem with my histogram is that it is quite small on the LCD and the bin size/width is not given in the manual and, worse, the column heights are auto-ranged to fit the histogram rectangle height and there is no scale shown on the Y-axis of the histogram diagram. So, for me, it is impossible to check accuracy because I don't know the bin width and I don't know the count for any particular bin.
    Would you share how you tested the accuracy of the Sony a74 histogram?
    June 19, 2023, 11:32 p.m.
    theres a thread i started with 1000 posts somewhere on this forum. are raw histograms important or something like that. good luck finding it.
    found it
    dprevived.com/t/raw-histogram-and-why-does-it-matter/1848/
    June 19, 2023, 11:38 p.m.
    To prove a fact, one post is usually enough.
    A histogram of a JPEG is an accurate (within histogram window width and height constraints) histogram of a JPEG. Ta-daaaa!
    June 19, 2023, 11:40 p.m.
    I don't know exactly what the Elephant-in-the-room uses but one standard says "When encoding Y’CBCR video, BT.709 creates gamma-encoded luma (Y’) using matrix coefficients 0.2126, 0.7152, and 0.0722"
    en.wikipedia.org/wiki/Rec._709
    So Luma would be 100% when 0.2126R+ 0.7152G+0.0722B=1.
    June 20, 2023, 12:03 a.m.
    Thanks - I see that you use RawDigger, this is your posted image:
    Donald screen shot
    Because the histogram can be scaled at least you can determine counts and bin sizes.
    June 20, 2023, 12:07 a.m.
    all the posted raw file links wont work as i have deleted the images they were clogging up mu one drive.
    any you will get the idea or maybe not its such a merry go round thread with a lot of off topic comments.
