Second hand X-Pro3, what to check before buying?
chat_bubble_outline 7
    Members 1805 posts
    May 4, 2023, 8:17 p.m. May 4, 2023, 8:17 p.m.
    I might buy a reasonably priced X-Pro3 and wondering what to check specifically for this model. I will test AF, sensor etc. But I don't know much about this model's weak points. I was going to wait for X-Pro 4 or new X100 but I don't think that it will come soon.
    Foskito
    Members 284 posts
    May 6, 2023, 12:16 a.m. May 6, 2023, 12:16 a.m.
    @Daneland has written:
    Seems like the weak point is the tilt screen, lots of info about it online.
    www.thephoblographer.com/2021/10/09/how-bad-is-the-fujifilm-x-pro-3-sub-monitor-issue/
    Daneland likes this.
    JohnGellings
    Members 30 posts
    May 6, 2023, 3:45 p.m. May 6, 2023, 3:45 p.m.
    As Foskito said, the screen is certainly the weak point. And there is no way to test if it will break. One day the sub monitor just goes and then the LCD. The only way to ensure it does not happen is to never flip open the screen.
    SquadShooters
    Members 125 posts
    May 7, 2023, 10:16 a.m. May 7, 2023, 10:16 a.m.
    In addition to the usual suspects that you should check on every body, I would also check the EVF & screen in the back.
    There are conflicting reports about the screen. Personally I don’t open it for more than 45º and did not encounter any issues (so far, knock knock). If it is used there is no way to find out how the body & screen were used, so there’s always some risk involved.
    JohnGellings
    Members 30 posts
    May 7, 2023, 11:56 a.m. May 7, 2023, 11:56 a.m.
    Conflicting reports? I can assure the issue is real because I had the issue.
    SquadShooters
    Members 125 posts
    May 7, 2023, 5:15 p.m. May 7, 2023, 5:15 p.m.
    Nobody said the issue isn’t real but it’s an unknown how many percent are affected and if this a design or manufacturing issue.
    And it’s obvious that the affected users are a vocal minority.
    Sprouty115 and jaberg like this.
    Threaded
    Members 164 posts
    May 9, 2023, 4:44 p.m. May 9, 2023, 4:44 p.m.
    Another thing to check is the shutter button, some of these have failed (or been poorly adjusted from factory). Take as many pictures as you can and get the feel of it, if you’re finding that it doesn’t always fire or you sometimes have to press harder than you expect, you’re probably not imagining it and it probably does have a fault.
    I had this on two different XP3’s, both from factory, I ignored it on one (and later sold it on) but the other eventually got worse to the point where Fuji replaced the top plate under guarantee - since then no problem.
    JohnGellings
    Members 30 posts
    May 9, 2023, 7:52 p.m. May 9, 2023, 7:52 p.m.
    @SquadShooters has written:
    We are starting to see people saying they've had it die twice. Extremely unlucky if so few are affected. You have to remember many people do not use their cameras very often. I see so many cameras (all brands) being sold with so few actuations and they are many years old. If people do not use their cameras often, it will take a long time to figure out if they have the issue.
