Shutter speed and auto Dynamic Range
rutolander
May 3, 2023
chat_bubble_outline 9
    rutolander
    Members 14 posts
    May 3, 2023, 1:29 p.m. May 3, 2023, 1:29 p.m.
    Just messing with X-H2s and no shutter speed in viewfinder, turned to to be that I had set dynamic range to auto.
    Why would I not need to know my shutter speed it don't make sense to me.
    I posted this in Open Talk probably not the best place so put it here as well
    ErikWithaK
    Members 209 posts
    May 3, 2023, 1:55 p.m. May 3, 2023, 1:55 p.m.
    @rutolander has written:
    With Auto-DR on, until you lock exposure (usually with a half-press of the shutter button) the camera hasn’t yet decided to go with either DR100 or DR200 and doesn’t know what the shutter speed will be.
    smadayug, JimKasson and NightPixel like this.
    rutolander
    Members 14 posts
    May 3, 2023, 10:16 p.m. May 3, 2023, 10:16 p.m.
    Thanks
    but it still doesn't say what it is even when you do press the button
    smadayug likes this.
    Forum Admin 3818 posts
    May 3, 2023, 10:29 p.m. May 3, 2023, 10:29 p.m.
    I just tried on mine in Auto-DR mode. When I half press the shutter, it then shows shutter speed and F-Stop.
    ErikWithaK
    Members 209 posts
    May 3, 2023, 10:34 p.m. May 3, 2023, 10:34 p.m.
    Thanks
    SHUTTER AE must be enabled (you should see it with AEL engaged too).
    SrMi
    Members 457 posts
    May 3, 2023, 11:03 p.m. May 3, 2023, 11:03 p.m.
    See Rico Pfirstinger’s book “X secrets” why Auto DR is a bad idea.
    smadayug, JimKasson and ErikWithaK like this.
    ErikWithaK
    Members 209 posts
    May 3, 2023, 11:10 p.m. May 3, 2023, 11:10 p.m.
    @SrMi has written:
    As a RAW shooter, I'm of the opinion that the DR modes are a bad idea in general..
    smadayug, Lewiedude, Fujijon and 1 other user like this.
    SrMi
    Members 457 posts
    May 3, 2023, 11:30 p.m. May 3, 2023, 11:30 p.m.
    @ErikWithaK has written:
    @SrMi has written:
    Ditto for raw files, and Rico agrees.
    smadayug and JimKasson like this.
    rutolander
    Members 14 posts
    May 4, 2023, 1 p.m. May 4, 2023, 1 p.m.
    I have found the problem it depends what mode you are in M,A,S,P but still I can't understand why it will not show shutter speed in aperture priority it just seem odd to keep it secret
    ErikWithaK
    Members 209 posts
    May 4, 2023, 2:24 p.m. May 4, 2023, 2:24 p.m.
    Because, with Auto DR on, the camera doesn’t decide which DR mode (and SS) to use until you lock the exposure - it’s an unknown. Could the implementation be different with a real-time display? Quite possibly, but it isn’t. If you want to see the SS value in real-time, simply don’t use Auto-DR.
