Supermoon 30-31 August 2023
DanHasLeftForum
Aug. 30, 2023
chat_bubble_outline 23
    DanHasLeftForum
    Members 4254 posts
    Aug. 30, 2023, 7:14 a.m. Aug. 30, 2023, 7:14 a.m.
    I'm hoping to be able to take some photos of the Blue Supermoon tonight (30/8) or tomorrow night but unfortunately the weather forecast at least for tonight is not good with overcast skies and maybe some rain.
    In the mean time here are a couple of images of previous supermoons to hopefully whet the appetite of anyone interested 🙂
    11 August 2022
    dprevived.com/media/attachments/71/3e/yQWPzazDjtAeRTukW1W6Haj3rH0u7b9WOqMsTjSC07h6AGZEDprMtUW5oJswPLfk/supermoon-11aug2.jpg
    9 March 2020
    dprevived.com/media/attachments/5a/de/7uf1AKsjTP9AWwqFLGMcIRoYOwHOyKMCDzP42SxqlzbO48cA8sik4Q4jBjPpw4k3/supermoon-9mar20.jpg
    JPG, 105.3 KB, uploaded by DannoB on Aug. 30, 2023.
    JPG, 104.1 KB, uploaded by DannoB on Aug. 30, 2023.
    simplejoy likes this.
    simplejoy
    Members 1927 posts
    Aug. 30, 2023, 9:16 a.m. Aug. 30, 2023, 9:16 a.m.
    @DannoB has written:
    11 August 2022
    9 March 2020
    Very nice moon shots - great detail in the second one. Thanks for the reminder - I'm not sure if there will be any opportunity for me to attempt capturing anything of it, but I'm looking forward to your results!
    DanHasLeftForum
    Members 4254 posts
    Aug. 30, 2023, 10:03 a.m. Aug. 30, 2023, 10:03 a.m.
    @simplejoy has written:
    Thank you simplejoy.
    Unfortunately not tonight. It's very overcast here at the moment so hopefully, fingers and toes crossed, the clouds will clear up by tomorrow evening.
    AlainCh2
    Members 603 posts
    Aug. 30, 2023, 11:30 a.m. Aug. 30, 2023, 11:30 a.m.
    I did it yesterday evening, but not lucky. [UT+2]
    Humid wind, no way to get a sharp shot.
    With a dry wind in July, same gear, I got a better result
    I will try again tonight.
    (maybe no wind ? )
    JPG, 731.6 KB, uploaded by AlainCh2 on Aug. 30, 2023.
    JPG, 661.5 KB, uploaded by AlainCh2 on Aug. 30, 2023.
    DanHasLeftForum
    Members 4254 posts
    Aug. 30, 2023, 12:26 p.m. Aug. 30, 2023, 12:26 p.m.
    With full moon close ups it's always more difficult to get sharp images because the light is hitting the moon 'face on' and so is very flat and harsh.
    In your second shot where the light is hitting the moon at an angle to it, shadows are cast creating more contrast and so it is much easier to get sharp images.
    Below are some some non full moon photos.
    dprevived.com/media/attachments/22/9f/qK5CQHGfkIoTsKxUBEmL6xuKPKxBA6OxP39uCelH4eFnzadc1jKUMwvncBcpCxC5/crescentmoon-1.jpg
    dprevived.com/media/attachments/dd/5a/vy6yyJd51PXX3wCwgGEq3Oye1MvOEA90pZkSMnLWDWfstjmXqzaxeG2LZXhPUmzf/crescentmoon-3.jpg
    dprevived.com/media/attachments/39/6e/kjokDgc76UgjgHnn8qvQ3IJH5mDFJCoGbgu67IDbPKGhp34RFlYqAwKeXxhoVOx3/crescentmoon-2.jpg
    JPG, 64.3 KB, uploaded by DannoB on Aug. 30, 2023.
    JPG, 90.2 KB, uploaded by DannoB on Aug. 30, 2023.
    JPG, 102.8 KB, uploaded by DannoB on Aug. 30, 2023.
    AlainCh2
    Members 603 posts
    Aug. 30, 2023, 1:43 p.m. Aug. 30, 2023, 1:43 p.m.
    That's what I thought.
    Even during daylight shots, I get them sharp
    ( windy it was )
    JPG, 970.9 KB, uploaded by AlainCh2 on Aug. 30, 2023.
    DanHasLeftForum
    Members 4254 posts
    Aug. 31, 2023, 12:11 a.m. Aug. 31, 2023, 12:11 a.m.
    In daylight it's a little easier because you can use faster shutter speeds, especially if it's windy.
    DanHasLeftForum
    Members 4254 posts
    Aug. 31, 2023, 10:47 a.m. Aug. 31, 2023, 10:47 a.m.
    Still no luck tonight with the weather. It's overcast with light on and off drizzle. The weather forecast for tomorrow is better so hopefully will get a chance to take some photos even though it won't quite be a super moon. I have plenty of close-up shots but few of the moon low above the horizon with other elements in the frame, so I'm hoping for better weather tomorrow night.
    stevet1
    Members 954 posts
    Aug. 31, 2023, 1:52 p.m. Aug. 31, 2023, 1:52 p.m.
    I got a couple of shots of the full moon last night though the trees. I used mirror lockup and a 2 second time delay on the shutter release. The are cropped because I liked the play of the branches across the face of the moon.
    I also spot metered off the moon, so the shutter speed and ISO are pretty low.
    JPG, 76.4 KB, uploaded by stevet1 on Aug. 31, 2023.
    DanHasLeftForum
    Members 4254 posts
    Aug. 31, 2023, 11:15 p.m. Aug. 31, 2023, 11:15 p.m.
    Very nice composition Steve and I too like the play of the branches across the face of the moon.
    But it's a pity the moon itself is clipped (nearly a solid white disk) on my screen.
    Are you sure your metering spot was on the actual moon and not on the branches/leaves because the slow shutter speed is consistent with the darker parts of the scene being metered?
    Normally if you spot meter a full moon, which in reality is very, very bright, I would expect a significantly faster shutter speed than 1/25s
    Thank you for sharing 🙂
    The weather is slightly overcast, AGAIN 😣, here this morning but the forecast is good so hopefully tonight the clouds will clear enough to allow me to try to get some low on the horizon moon shots. Moonrise is at 7:24pm tonight (still 97.2% full), well after sunset at 5:58pm.
    DanHasLeftForum
    Members 4254 posts
    Sept. 1, 2023, 12:27 p.m. Sept. 1, 2023, 12:27 p.m.
    The clouds cleared up late this afternoon 🙂
    Even though the supermoon was last night, the moom was only slightly further away from earth this evening and still 97% illuminated.
    Below are 3 of the photos I took this evening - two looking at the moon through trees and one "close-up".
    dprevived.com/media/attachments/9b/90/oE8Rr0J0hF9bw3ZCL14y6eLS24io06Yq90c4L7jJHkuSOsLt44byEtTF0tP3DVc1/supermoon-2.jpg
    dprevived.com/media/attachments/be/af/dIV5MkgKRfzkeIKCznswPc8yHdCk9cCdCvAcSRpHxOTaCTgPDymG3osRAnlSStKB/supermoon-1.jpg
    dprevived.com/media/attachments/a0/8b/byBpwcHXSYW76mwna4uGIslLW3Wk4Yy7LCDlEhjZQfhsX5q74aBZl13HT0UGumZu/supermoon-3.jpg
    JPG, 85.9 KB, uploaded by DannoB on Sept. 1, 2023.
    JPG, 103.9 KB, uploaded by DannoB on Sept. 1, 2023.
    JPG, 79.3 KB, uploaded by DannoB on Sept. 1, 2023.
    stevet1
    Members 954 posts
    Sept. 1, 2023, 12:47 p.m. Sept. 1, 2023, 12:47 p.m.
    DannoB.,
    Thank you for your comments.
    I puzzled over this all day yesterday, and I think I figured it out. It has to do with this Cautionary note in my manual:
    I realized that I was raising my camera slightly to meter off the moon, but what I was actually doing was lifting the front leg of my tripod slightly. After I metered, and relaxed my grip, the tripod was lowering slightly, just enough to drop the center of the frame down into the darkness below the moon;s surface. Then, when I pressed the shutter button, the camera metered the shot just as the picture was taken.
    At least, I think that was it.
    Thanks for your help.
    JPG, 38.9 KB, uploaded by stevet1 on Sept. 1, 2023.
    DanHasLeftForum
    Members 4254 posts
    Sept. 1, 2023, 12:59 p.m. Sept. 1, 2023, 12:59 p.m.
    No problem 🙂. That sounds like the most likely reason for what happened.
    A work-around you could try is to use manual mode. Spot meter the important part of the scene and then zero the meter adjusting aperture, shutter speed and ISO to suit.
    RLBur
    Members 6 posts
    Sept. 1, 2023, 2:33 p.m. Sept. 1, 2023, 2:33 p.m.
    Here are a couple of my shots of the supermoon...shot low on the horizon.
    Sony RX10 Mk4
    JPG, 12.5 MB, uploaded by RLBur on Sept. 1, 2023.
    JPG, 2.5 MB, uploaded by RLBur on Sept. 1, 2023.
    JimStirling and DannoB like this.
    RLBur
    Members 6 posts
    Sept. 1, 2023, 2:43 p.m. Sept. 1, 2023, 2:43 p.m.
    Nice shots, I especially like the framing thru the tree.
    Randy
    This post was to DannoB.
    JimStirling
    Members 197 posts
    Sept. 1, 2023, 10:28 p.m. Sept. 1, 2023, 10:28 p.m.
    I gave it a go using my OM-1 with adapted manual focus Nikon 300mm f/2.8 AI-s ED giving an effective FOV of 600mm FF , this is crop from the frame
    JPG, 1.2 MB, uploaded by JimStirling on Sept. 1, 2023.
    DannoB likes this.
    DanHasLeftForum
    Members 4254 posts
    Sept. 1, 2023, 11:19 p.m. Sept. 1, 2023, 11:19 p.m.
    @RLBur has written:
    Sony RX10 Mk4
    Nicely done 🙂 I like the compositions of both.
    I can see after you took the "1230" shot you moved to the right to place the moon between the tree's two trunks for the "1233" shot. Very nice 🙂
    Thank you for sharing.
    DanHasLeftForum
    Members 4254 posts
    Sept. 1, 2023, 11:23 p.m. Sept. 1, 2023, 11:23 p.m.
    @RLBur has written:
    Randy
    Thank you RLBur 🙂. I assume you mean the super moon photos from last night and not in my op. The silhouetted branches are a little clearer on my computer monitor than how they appear in my browser.
    It was well after sunset when I took those photos whereas there was still some "day light" when I took the photos in my op of the moon through the trees.
    RLBur likes this.
    DanHasLeftForum
    Members 4254 posts
    Sept. 1, 2023, 11:27 p.m. Sept. 1, 2023, 11:27 p.m.
    @JimStirling has written:
    Very nice and very well done Jim.
    JimStirling and RLBur like this.
    RLBur
    Members 6 posts
    Sept. 1, 2023, 11:33 p.m. Sept. 1, 2023, 11:33 p.m.
    I'm trying to figure out who I'm posting to.
    I'll just say, I've enjoyed all the photos posted here of the moon! Lol
    Randy
    JimStirling likes this.
    RLBur
    Members 6 posts
    Sept. 1, 2023, 11:34 p.m. Sept. 1, 2023, 11:34 p.m.
    Thank you, DannoB.
    Vahur
    Members 861 posts
    Sept. 2, 2023, 4:12 p.m. Sept. 2, 2023, 4:12 p.m.
    Tried to shoot moon but weather was not cooperative, sky was cloudy and moon was lost in clouds 20 minutes after rise, so only shots I got were not very sharp due to atmosphere interference and did not have nice foreground. On plus side I managed to capture moon's rings 😁
    JPG, 327.0 KB, uploaded by Vahur on Sept. 2, 2023.
    JimStirling, davidwien and simplejoy like this.
    DanHasLeftForum
    Members 4254 posts
    Sept. 3, 2023, 6:21 a.m. Sept. 3, 2023, 6:21 a.m.
    @Vahur has written:
    I like it 🙂 The clouds make a nice "rings" effect.
    AlainCh2
    Members 603 posts
    Sept. 5, 2023, 4:55 p.m. Sept. 5, 2023, 4:55 p.m.
    Finally, my shots are ready
    Nikon Z30 Sigma 150-600C TC1401
    ISO1000 - 1/500 - F16
    with TC
    live.staticflickr.com/65535/53165735991_e7a141f04b_k.jpg
    Without TC
    live.staticflickr.com/65535/53165736106_5223fddee8_k.jpg
