  • label Open Open discussions
The Exposure Triangle
DanHasLeftForum
June 19, 2023
chat_bubble_outline 100
    DanHasLeftForum
    Members 4254 posts
    June 19, 2023, 7:24 a.m. June 19, 2023, 7:24 a.m.
    exposure-triangle.com
    dprevived.com/media/attachments/80/e4/Htb2u8zCQQs3XHS8KlhSgnJXsrcguhKurYhD6AhtoYV9d4mFjJvOf2ZnvChQnKBR/whywhy.gif
    GIF, 3.0 MB, uploaded by DannoLeftForums on June 19, 2023.
    DonaldB
    Members 2635 posts
    June 19, 2023, 7:58 a.m. June 19, 2023, 7:58 a.m.
    @DannoLeftForums has written:
    The ultimate luminosity meter = EVF 😁
    Danny
    Members 435 posts
    June 19, 2023, 8:12 a.m. June 19, 2023, 8:12 a.m.
    It's actually very easy to explain.
    It's because it's on the dark side of the moon. Hey, that would be a good album title.
    JPG, 1.4 MB, uploaded by Danny on June 19, 2023.
    DanHasLeftForum
    Members 4254 posts
    June 19, 2023, 8:36 a.m. June 19, 2023, 8:36 a.m.
    @DonaldB has written:
    Nope. That is total nonsense 😊
    The in camera histogram is at best an approximation of the raw histogram because the in camera histogram is based on the rgb values processed from the raw data.
    For a given scene luminance the in camera histogram will vary depending on variables like the metering mode, the WB setting, the camera's 'picture style' settings set by the user etc.
    dprevived.com/media/attachments/27/91/aAr96IpuIEmK63CKAYCYCaqpLs8oOLAs1nVM8qk1s7yLXb5ACDXhT2ugqD3wHvFI/eatingpopcorn2.gif
    PeteW
    Members 185 posts
    June 19, 2023, 10:04 a.m. June 19, 2023, 10:04 a.m.
    Simple. Because photography is all about ISO. That's why cameras have an ISO button or a dial, and lots of other ISO features. Photographers should always set their ISO first and let the camera worry about everything else automatically.
    phototaker and DannoLeftForums like this.
    finnan
    Members 322 posts
    June 19, 2023, 1:40 p.m. June 19, 2023, 1:40 p.m.
    HAND.
    finnan
    Members 322 posts
    June 19, 2023, 1:52 p.m. June 19, 2023, 1:52 p.m.
    HAND.
    ggbutcher likes this.
    Deleted Removed user
    June 19, 2023, 3:25 p.m. June 19, 2023, 3:25 p.m.
    @PeteW has written:
    To read the above reinforces my opinion that the number found on film canisters should never have found it's way into the world of digital camera adjustment.
    IanSForsyth, TonyBeach, bobn2 and 2 other users like this.
    DonCox
    Members 280 posts
    June 19, 2023, 3:39 p.m. June 19, 2023, 3:39 p.m.
    @finnan has written:
    @PeteW has written:
    Higher ISO is but a cheat, when the photographer fails to provide adequate scene illumination.
    No photo without sufficient light, so that's what photographers should worry about first.
    Setting a higher ISO number is telling the metering system to give less exposure. It's the same as Exposure Compensation but also tells the JPG engine to try to reduce the damage.
    It gives less camera shake but more noise.
    Don
    TonyBeach likes this.
    DonCox
    Members 280 posts
    June 19, 2023, 3:42 p.m. June 19, 2023, 3:42 p.m.
    @xpatUSA has written:
    @PeteW has written:
    You're probably right, Ted.
    Don
    Deleted likes this.
    knickerhawk
    Members 31 posts
    June 19, 2023, 10:04 p.m. June 19, 2023, 10:04 p.m.
    I didn't register, so I didn't get access to his "cheat sheets" but he actually isn't promoting the exposure triangle on his teaser homepage. In fact, he goes to some pains to explain that the exposure triangle is "wrong". It appears he's using "exposure triangle" as a kind of internet search honeypot to attract misinformed/novice photographers to his training stuff.
    JohnVickers, JimStirling and Deleted like this.
    DonaldB
    Members 2635 posts
    June 20, 2023, 1:37 a.m. June 20, 2023, 1:37 a.m.
    This is a couple of quotes from another tread 😁
    I'm wondering how Pete knew what the scene brightness was ...
    I determined it using the exposure triangle.
    Gold 😁
    Deleted likes this.
    SrMi
    Members 457 posts
    June 20, 2023, 4:04 a.m. June 20, 2023, 4:04 a.m.
    On the other hand, this makes more sense:
    exposure-triangle.com/#exposure_in_photography
    (Scroll down to “What are the components of exposure” - brightness of the scene, aperture, and shutter speed)
    DonaldB
    Members 2635 posts
    June 20, 2023, 6:05 a.m. June 20, 2023, 6:05 a.m.
    @SrMi has written:
    how do you measure the brightness of a scene 😊 and what components/functions in camera do you need to display them 😊
    bobn2
    Team 2240 posts
    June 20, 2023, 7:51 a.m. June 20, 2023, 7:51 a.m.
    @SrMi has written:
    Still contains the myth that ISO is 'the gain'. In any case, what is a beginner supposed to make of 'gain' without explanation? What is being 'gained'?
    JimStirling likes this.
    DonaldB
    Members 2635 posts
    June 20, 2023, 8:40 a.m. June 20, 2023, 8:40 a.m.
    @bobn2 has written:
    @SrMi has written:
    without gain you have no image. how many OP amps are before ADC 😊 in fact the photo diode voltage/charge isnt the voltage thats even sampled.
    An operational amplifier is a DC-coupled high-gain electronic voltage amplifier with a differential input and, usually, a single-ended output. In this configuration, an op amp produces an output potential that is typically 100,000 times larger than the potential difference between its input terminals.
    ISO IS THE GAIN
    The truth is, it’s much easier than that. ISO is the gain that is applied to the amount of light your camera sensor has “recorded”. And being exactly that, the gain, it has nothing to do with exposure. It is applied by the cameras processor long after the shutter has closed.
    Nevertheless, the gain has an influence on image brightness
    Summary: higher gain (ISO) – brighter image
    PeteW likes this.
    finnan
    Members 322 posts
    June 20, 2023, 9:24 a.m. June 20, 2023, 9:24 a.m.
    HAND.
    DanHasLeftForum
    Members 4254 posts
    June 20, 2023, 9:35 a.m. June 20, 2023, 9:35 a.m.
    @bobn2 has written:
    @SrMi has written:
    ISO IS THE GAIN
    At base iso many cameras apply no gain and still output an image.
    In the PAS modes raising iso maintains the same image lightness because either shutter speed or aperture are adjusted to reduce the exposure* by the same amount thus maintaining the same image lightness.
    * exposure. - amount of light that struck the sensor per unit area while the shutter was open.
There are 83 more posts in this thread.
