TZ100 question
chat_bubble_outline 7
    Forum Admin 3797 posts
    June 5, 2023, 9:41 p.m. June 5, 2023, 9:41 p.m.
    I've just got a TZ100. It produces nice snaps but one thing really irritates me. How can I get rid of the feature that, when I half press the shutter, it magnifies the middle part of the image in the viewfinder? I can reduce the time it's there, but I can't see how to stop it happening in the first place.
    Any clues?
    AlbertM43user
    Members 56 posts
    June 6, 2023, 11:05 a.m. June 6, 2023, 11:05 a.m.
    I read your similar posting on DPR.
    2 shooting modes will bring up PIP screen (magnification of the focus box). Either in MF mode, or using Pin Point Focus mode.
    The answer had been posted on DPR's Panny Compact Forum, not duplicate here.
    June 6, 2023, 11:38 a.m. June 6, 2023, 11:38 a.m.
    Thank you.
    For those who don't get over to DPReview, I was using 'pin point' focussing mode - which is the smallest square. I did this because that's what I've always used.
    The full answer is here www.dpreview.com/forums/thread/4714701#forum-post-67068295
    DonaldB
    Members 2628 posts
    June 6, 2023, 11:50 a.m. June 6, 2023, 11:50 a.m.
    @AlanSh has written:
    Thank you.
    from past experience from several brands the smallest af point is not very accurate. ive always used the next size up for better
    focus accuracy.
    Ghundred
    Members 811 posts
    June 6, 2023, 12:01 p.m. June 6, 2023, 12:01 p.m.
    @DonaldB has written:
    focus accuracy.
    Panasonic is quite different here. The pinpoint focus crosshairs is absolutely dead accurate. As accurate as you can get. It doesn't cover the entire sensor area, and it's definitely a little bit slower and steady, but it more than makes up for that with accuracy. It also doesn't work in AF-C mode, due to the focus speed slowdown required for accuracy
    June 6, 2023, 12:09 p.m. June 6, 2023, 12:09 p.m.
    Thanks both for the information.
    I did find that the smallest point is accurate with my limited (1 day) testing. But I can't stand how the screen zooms in for a short while and then goes back to 'normal' - so I'll go with the next size up for a few days and see how that goes.
    Ghundred
    Members 811 posts
    June 6, 2023, 12:44 p.m. June 6, 2023, 12:44 p.m.
    On the small sensor, you probably won't notice any minor focus misses using larger focus boxes.
    On my Sigma 56 f1.4, shooting wide open at close distances, it's the only way to fly. It honestly is dead bang spot on every time. Unless something moves.
    On a shot like this, you can pick any edges of any letter you like, and it will simply nail it. Every time
    JPG, 600.1 KB, uploaded by Ghundred on June 6, 2023.
    June 6, 2023, 1:34 p.m. June 6, 2023, 1:34 p.m.
    Yes, but this is a 1" sensor with a fixed zoom lens. So, there's a bit of leeway in the focussing.
