Updating lens firmware using XH2
tprevatt
May 5, 2023
chat_bubble_outline 4
    tprevatt
    Members 775 posts
    May 5, 2023, 11:21 p.m. May 5, 2023, 11:21 p.m.
    I need to update my wife's 50-140. In the past with the X series the new firmware had to be in the root in slot 1 in on a reformatted SD card.
    How does this work using the XH2? Does it need to be in slot 1 which means the CFX card?
    Thanks.
    Morris
    Members 285 posts
    May 6, 2023, 1:56 p.m. May 6, 2023, 1:56 p.m.
    On the X-H2s the manual states either card. The rest of the procedure is identical to the past.
    Morris
    NightPixel, smadayug and ChuckEklund like this.
    Baobob
    Members 128 posts
    May 6, 2023, 4:51 p.m. May 6, 2023, 4:51 p.m.
    @tprevatt has written:
    Thanks.
    Did it with the SD card as usual without problem.
    The 50-140mm is amazing
    NightPixel and smadayug like this.
    rutolander
    Members 14 posts
    May 7, 2023, 9:08 a.m. May 7, 2023, 9:08 a.m.
    @Baobob has written:
    Thanks.
    Same here used SD Card X-H2s no problem with it
    smadayug likes this.
    NightPixel
    Members 19 posts
    May 8, 2023, 7:48 p.m. May 8, 2023, 7:48 p.m.
    I used the Compact Flash card without issue. I guess the camera will search both cards looking for the firmware file.
