• Members 657 posts
    July 29, 2025, 6:01 a.m.
    It’s easy to participate
    Thread Guidelines:
    ”Likes” are encouraged too.
    Experimentation might include, Infrared, dragged shutter, zone plate, motion, 3D, fluorescence, multiple exposure, birefringence, ultra violet, optical including adapted lenses, tri color, fractals, manipulated Polaroids, pinhole, Kirlian (bioelectrography) and many other methods. Experimentation can be for artistic expression or pure science. It is often more difficult than standard types of photography. This is fine, we aren't expecting perfection. Every experiment enhances knowledge. Your idea can help others explore the universe around them. We love experimentation. You can explain your process or keep it a secret.
    This will be a looser collection of photos compared to other weekly threads. This is good. It will be a place to get away from standard animals, babies & sunset photos. We don't hate animals, babies or sunsets. Show us your creative abstract and experimental images. Don't worry, if you are unsure, if the image fits the category. Just post it. This is supposed to be fun.
    barondla
  • Members 657 posts
    July 29, 2025, 6:20 a.m.
    This is an ultraviolet induced visual fluorescence image (UVIVF). I used a 365 nm ultraviolet flashlight, with the supplied dark filter, to paint standard objects at night. Certain objects give off visible light when illuminated by ultraviolet light. This was done with a stock, unmodified, camera. A very strong Tiffen UV filter was used to allow only visible light to reach the camera sensor. The special UV filter allows the colors to be a little purer. You can take these photos without the special UV filter.
    Thanks for looking,
    barondla
    JPG, 644.9 KB, uploaded by barondla on July 29, 2025.
  • Members 2517 posts
    July 29, 2025, 2:18 p.m.
    A nature abstract
    Angel Glacier on Mount Edith Cavell in Jasper NP, Alberta, CA.
    There was nothing to use to show scale for the framing I wanted but the little floating iceberg was about the height of a big spruce tree at the same distance in another direction.
    JPG, 2.6 MB, uploaded by minniev on July 29, 2025.
    July 29, 2025, 2:19 p.m.
    I really need to get one of those filters to play with. This is quite beautiful.
  • Members 657 posts
    July 29, 2025, 8:55 p.m.
    Excellent abstract. Without knowing the size of the iceberg, it is impossible to gauge the size of the subject. The slanting lines form arrows when combined with their reflections. The "arrows" lead the viewer through the composition. Well done. The blue/green to mint is a nice color transition. Subtle, but nice. Was this taken from land or boat?
    barondla
  • Members 1722 posts
    July 30, 2025, 8:11 a.m.
    Other than basic pp there were no special effects used here. Backlit and some foreground grass providing the effect.
    JPG, 1.4 MB, uploaded by Bryan on July 30, 2025.
  • Members 657 posts
    July 30, 2025, 9:01 p.m.
    Thank you. The flashlight is the most important part. It needs to be 365nm and have the black filter to block everything but UV light. There are bazillion of ones on eBay that are poorly designed. If you decide you want to get one later let me know and I will find a link to the exact one. It is one recommended by ultravioletphotography.com.
    You can do these photos in the dark without an UV filter on the camera. The colors just won't be quite as pure. The only UV filters strong enough are Tiffen UV or Haze 2A or 2E. Sometimes Tiffen uses Haze and sometimes UV to desecribe the same filters. The only other choice is Zeiss UV T*. If you buy the Zeiss make sure it is from a place that allows returns. There are counterfeit filters. My used Zeiss came from usedphotopro.com. I conversed with them before purchasing and the owner said she had no way to test for UV, but it would be happily refunded if not legit. The filter was fine.
    I own all 3 and have listed them in order of strength. Stronger the filter the more blue is cut out. All work great.
    barondla
  • Members 657 posts
    July 30, 2025, 9:23 p.m.
    Magical image. Beautiful bird and an amazing background. The background is just incredible. Everything came together in a perfect mix. You should print this large and hang it on a wall.
    barondla
    July 31, 2025, 8:03 a.m.
    Thanks Barondia
    Luck's a fortune. I wasn't going to take that shot because I assumed the backlight too strong and that the bird would be too dark. Turned out there was enough filtered light. What I didn't say before was that I had to use manual focus because of the grass in front.
  • Members 657 posts
    July 31, 2025, 4:23 p.m.
    Glad you took the shot. Not taking a shot guarantees no results. AF would have likely ruined the shot. Would have captured beautifully sharp grass and bird blob.
    barondla
  • Members 1241 posts
    Aug. 1, 2025, 8:21 p.m.
    Wondeful shot. I love that glacier blue - it makes the hairs on the back of my neck stand up whenever I see it for real. The semi-abstract works well; I have similar shots from the same spot but not quite so 'unscaled'. Magnificent location.
    Aug. 1, 2025, 8:28 p.m.
    Deep Time
    In a quarry somewhere in Scotland lie the remains of reptiles from Late Permian times.
    JPG, 5.8 MB, uploaded by Woodsider79 on Aug. 1, 2025.
  • Members 657 posts
    Aug. 2, 2025, 1:27 a.m.
    Quite mysterious and ancient. The subtle tones and colors add to the feel. Excellent capture and execution. I like the out of the ordinary take on this subject.
    barondla
  • Members 366 posts
    Aug. 3, 2025, 4:20 p.m.
    Construction made of elements with a honeycomb-shaped section.
    (for cross-viewing)
    JPG, 1.5 MB, uploaded by 3DGunner on Aug. 3, 2025.
  • Members 657 posts
    Aug. 4, 2025, 12:12 a.m.
    One of my favorite 3D constructions. The honeycomb section adds a lot. As usual, the colors are spectacular. Dramatic image.
    barondla
  • Members 366 posts
    Aug. 4, 2025, 5:19 p.m.
    Thanks for the appreciation!
    These are some details from another perspective.
    (for cross-viewing)
    JPG, 1.4 MB, uploaded by 3DGunner on Aug. 4, 2025.
  • Members 657 posts
    Aug. 4, 2025, 11:36 p.m.
    Another excellent image. The additional foreground adds an amazing amount of extra depth. Didn't expect that, but it is neat. I find this image a little easier to view in stereo. Haven't figured out why some 3D images lock in easier than others.
    barondla
  • Members 366 posts
    Aug. 10, 2025, 2:51 p.m.
    Finally, a Hive.
    JPG, 2.3 MB, uploaded by 3DGunner on Aug. 10, 2025.
  • Members 657 posts
    Aug. 10, 2025, 5:14 p.m.
    Wow! Incredible image. Staggering amount of details. The jewel like precision is fantastic. I like that the image foreground features warm colors and it moves to a cool background.
    barondla
