• Members 646 posts
    Oct. 6, 2025, 4:48 p.m.
    It’s easy to participate
    Thread Guidelines:
    ”Likes” are encouraged too.
    Experimentation might include, Stereo/3D, macro, Infrared, dragged shutter, zone plate, motion, fluorescence, multiple exposure, birefringence, ultra violet, optical including adapted lenses, tri color, fractals, manipulated Polaroids, pinhole, Kirlian (bioelectrography) and many other methods. Experimentation can be for artistic expression or pure science. It is often more difficult than standard types of photography. This is fine, we aren't expecting perfection. Every experiment enhances knowledge. Your idea can help others explore the universe around them. We love experimentation. You can explain your process or keep it a secret.
    This will be a looser collection of photos compared to other weekly threads. This is good. It will be a place to get away from standard animals, babies & sunset photos. We don't hate animals, babies or sunsets. Show us your creative abstract and experimental images. Are you unsure if the image fits the category? Don't worry, just post it. FEEL FREE TO POST MULTIPLE TIMES TO THIS THREAD. This should be fun.
    barondla
  • Members 646 posts
    Oct. 6, 2025, 4:50 p.m.
    Lensbaby Composer double glass optic at F2.
    barondla
    JPG, 324.5 KB, uploaded by barondla on Oct. 6, 2025.
  • Members 2517 posts
    Oct. 6, 2025, 7:50 p.m.
    The sweetgum tree by my driveway, and some of its fallen leaves, reflected in the windshield and hood of our car.
    JPG, 2.3 MB, uploaded by minniev on Oct. 6, 2025.
  • Members 646 posts
    Oct. 7, 2025, 1:08 a.m.
    Wow! It moves from realistic to Japanese anime or painting. Impressive. Love the transition. You should enlarge and hang it on the wall.
    barondla
  • Members 1218 posts
    Oct. 7, 2025, 11:51 a.m.
    Multi exposure playing
    Last week I mentioned in-camera multi exposure images, and that sometimes I play with changing the white balance between exposures. Here are a couple fo experiments;
    Lasy week's lily pads by minniev reminded me of this little scene.
    A different attempt. More architectural. A bit too busy I think.
    I haven't quite worked out yet what sort of scene best suits this idea. Good to keep playing 😁
    JPG, 3.5 MB, uploaded by Woodsider79 on Oct. 7, 2025.
    JPG, 4.4 MB, uploaded by Woodsider79 on Oct. 7, 2025.
    Oct. 7, 2025, 11:53 a.m.
    Wonderful!
    A lesson to us all to keep the car clean 😅
  • Members 545 posts
    Oct. 7, 2025, 12:19 p.m.
    A bit of a boat
    Mirror lens doughnuts
    JPG, 530.6 KB, uploaded by DavidMillier on Oct. 7, 2025.
    JPG, 2.4 MB, uploaded by DavidMillier on Oct. 7, 2025.
  • Members 646 posts
    Oct. 7, 2025, 9:12 p.m.
    Fascinating idea. I like the different white balances mixed with multiple exposures. Guessing you are using same exposure for each. Have you tried using different exposures for each part? Experimentation is part of the fun. You are on to something here and it might work better with slightly less complicated subjects than the industrial photo. Looking forward to more examples.
    barondla
  • Members 646 posts
    Oct. 8, 2025, 2:42 a.m.
    Love how you distilled the boat down to an almost abstract image. The details in the wood keep it from being totally abstract.The red, white and blue stripes work well together. Very dramatic capture.
    barondla
    Oct. 8, 2025, 1:35 p.m.
    Yes, I have tried varying exposure between shots. It affects which image becomes more dominant in the composite.
    I believe some cameras have a variety of blending modes which you can select, but my Olympus just has the one mode. It also has 'auto gain' setting, which has the effect of compensating for the additional exposure. I usually turn it off, as I want to give equal weight to each exposure. But this means I have to 'compensate' manually; If I'm going to use two exposures, then dial in -1exp. compensation. -2 for four exposures and so on. It's not critical so long as the total doesn't blow important highlights.
  • Members 646 posts
    Oct. 8, 2025, 9:08 p.m.
    Fine use of mirror lens donuts. That's a lot of donuts. Like the panoramic format you used. B&W is an interesting choice as well. Experimentation is good. What mirror lens do you have?
    barondla
  • Members 45 posts
    Oct. 9, 2025, 2:59 a.m.
    These are a couple of photos I took in Adelaide Botanic Gardens a few months ago with an Infra Red filter on my lens. Unfortunately, Sony cameras have a pretty strong infra red cut filter on the sensor so it's not easy to get the effects you can get with some other brands but having said that, I'm pretty happy with these.
    JPG, 1.1 MB, uploaded by RichardA on Oct. 9, 2025.
    JPG, 653.6 KB, uploaded by RichardA on Oct. 9, 2025.
  • Members 646 posts
    Oct. 9, 2025, 5:57 p.m.
    They turned out wonderful. Beautiful colors and quite sharp. As you've shown it is possible to shoot infrared with a stock camera. They just require many more stops of light. Hope you post more images.
    barondla
  • Members 2395 posts
    Oct. 10, 2025, 7:25 p.m.
    This one catches the dreamy vibe of IR the best I think.
  • Members 545 posts
    Nov. 3, 2025, 7:46 a.m.
    I missed this question, sorry for the delay in responding!
    Hanimex 300mm, a fairly cheap and generic design with a T2 mount.
  • Members 646 posts
    Nov. 10, 2025, 5:19 p.m.
    I have a very similar Quantaray 300 F5.6 mirror lens with T2 mount. I've just started experimenting with to filters on the back element to strip visual and IR light out to record UV.
    Thanks for answering my question,
    barondla
