• Members 711 posts
    Dec. 15, 2025, 5:51 p.m.
    It’s easy to participate
    Thread Guidelines:
    ”Likes” are encouraged too.
    Experimentation might include, Stereo/3D, macro, Infrared, dragged shutter, zone plate, motion, fluorescence, multiple exposure, birefringence, ultra violet, optical including adapted lenses, tri color, fractals, manipulated Polaroids, intentional camera movement, pinhole, Kirlian (bioelectrography) and many other methods. Experimentation can be for artistic expression or pure science. It is often more difficult than standard types of photography. This is fine, we aren't expecting perfection. Every experiment enhances knowledge. Your idea can help others explore the universe around them. We love experimentation. You can explain your process or keep it a secret.
    barondla
  • Members 711 posts
    Dec. 15, 2025, 5:59 p.m.
    Pentax K-20D with Lensbaby Composer. ISO 3200 .7 seconds. Camera set to B&W mode.
    barondla
    JPG, 468.9 KB, uploaded by barondla on Dec. 15, 2025.
  • Members 382 posts
    Dec. 20, 2025, 2:09 p.m.
    "The Big Room at Carlsbad Caverns is North America's largest single cave chamber, spanning 8.2 acres and featuring massive formations like the Hall of Giants. Visitors walk a 1.25-mile, relatively flat loop trail to see its grandeur, with options to take the Natural Entrance (steep hike) or an elevator down. It's a must-see, known for its spectacular size and formations, requiring a jacket as it's cool inside.
    Trail: 1.25-mile loop, mostly flat, takes about 1.5 hours, with a shorter 45-minute cut-off."
    The panorama has a FoV of over 200 degrees and was assembled from 2x ten separate images, with different exposures in RAW, to compensate for the large lighting differences between bright and dark areas.
    JPG, 1014.8 KB, uploaded by 3DGunner on Dec. 20, 2025.
  • Members 711 posts
    Dec. 20, 2025, 6:22 p.m.
    Truly grand image. So many things to see in this one. You did an excellent job handling the extreme contrast range and stitching the pano together.
    The formations and colors are beautiful.
    This and Mammoth Cave are on my list to visit one day. Your pano must have taken quite a while to shoot? So the authorities are ok with people taking their time and doing photography. Unless they enforce a schedule I'd never make it out in 1.5 hours 😀. Wonderful photo! Amazing wall hanger if you have the room.
    barondla
  • Members 382 posts
    Dec. 20, 2025, 7:42 p.m.
    When I visited the cave, the rules were very simple: Follow the route and don't make any noise. Otherwise, you could stay in the cave as long as you wanted, until the program closed. I photographed the entire tourist area in about 7 hours, to integrate the photo material into a 3D photo album.🙂
  • Members 711 posts
    Dec. 22, 2025, 12:05 a.m.
    Seven hours is an awesome photo shoot. Glad they don't put time limits on photographers. Bet your 3D album is fabulous. How much did you bracket each pano section?
    Thanks for sharing,
    barondla
  • Members 382 posts
    Dec. 22, 2025, 7:25 a.m.
    Thanks for the appreciation.🙂
    If I remember correctly, I think the exposures were 2s and 12s at ISO 200. I should look for the originals for more precise data.
    I have a free wall about 4 meters long, but I use it as a projection screen.😀
  • Members 1342 posts
    Dec. 29, 2025, 5:36 p.m.
    Early Morning dew-drops on a spider's web looking like diamonds:
    The spider lives in a ground-level depression and spins a horizontal surface web.
    JPG, 773.5 KB, uploaded by xpatUSA on Dec. 29, 2025.
  • Members 711 posts
    Dec. 29, 2025, 10:43 p.m.
    Terrific image. The dew drops pop nicely from the background. Like that the background shows some detail and texture. This isn't an easy photo to pull off. Exposure and focus have to be just right and hopefully there's no wind. Extra points for using a Sigma 😀.
    barondla
  • Members 1927 posts
    Dec. 30, 2025, 12:24 a.m.
  • Members 711 posts
    Dec. 30, 2025, 1:54 a.m.
    Abstract and hypnotic is quite a combination. Interlocking colors strengthen the picture and add interest. The black background supports the subject without distraction.
    barondla
