• Members 762 posts
    Feb. 3, 2026, 9:49 p.m.
    It’s easy to participate
    Thread Guidelines:
    ”Likes” are encouraged too.
    Experimentation might include, Stereo/3D, macro, Infrared, dragged shutter, zone plate, motion, fluorescence, multiple exposure, birefringence, ultra violet, optical including adapted lenses, tri color, fractals, manipulated Polaroids, intentional camera movement, pinhole, Kirlian (bioelectrography) and many other methods. Experimentation can be for artistic expression or pure science. It is often more difficult than standard types of photography. This is fine, we aren't expecting perfection. Every experiment enhances knowledge. Your idea can help others explore the universe around them. We love experimentation. You can explain your process or keep it a secret.
    Thanks for viewing and participating,
    barondla
  • Members 762 posts
    Feb. 3, 2026, 10:11 p.m.
    Olympus E-PL1 with Fujinon 2.7mm F1.8 fisheye lens. This lens was rescued from a surplus surveillance camera. It is C mount and the adapter is recessed to allow infinity focus. There is no focusing helicoid since the depth of field is incredible. For close focusing the lens can be slightly unscrewed from the adapter. The lens doesn't have adjustable aperture. It is always wide open at F1.8. Lens can be picked up for about $65 attached to the surveillance camera. Lens gives circular image on m4/3 and full frame on smaller format Pentax Q.
    Used the corn's silhouette to partially disguise the circular fisheye effect. The sky was over exposed due to shooting at F1.8. Orange was added in post processing.
    barondla
    JPG, 91.9 KB, uploaded by barondla on Feb. 3, 2026.
  • Members 1357 posts
    Feb. 7, 2026, 4:41 p.m.
    Your Image reminded me of an experiment I did years ago when in Cappodocia. I came across a little 'clearing' among the 'fairy chimneys' and thought I'd try one of those 'fish-eye' panoramas. My first attempt was a startling failure, but somehow I liked the weirdness of it and have never deleted it 😄(30 imgages stiched)
    A second attempt was more 'successful' - 27 images.
    JPG, 1.7 MB, uploaded by Woodsider79 on Feb. 7, 2026.
    JPG, 4.8 MB, uploaded by Woodsider79 on Feb. 7, 2026.
  • Members 762 posts
    Feb. 7, 2026, 6:14 p.m.
    Excellent fisheye panoramas. Glad you didn't delete the “bizarro world“ version. It Is my favorite of the two, and knocks it out of the park. Both images are a breath of fresh air in the static landscape category. 27 and 30 shots seem like a lot to make a fisheye pano. Why did you use so many? Now I gotta try a fisheye pano.
    Second image has a primeval look. Expecting to see a giant pterodactyl flying in the sky. With so much sky included was it difficult to get a proper exposure? I like the image a lot.
    I've had a few interesting pano stitching results but nothing approaching the greatness of yours. One of my 50 image focus stack did come out so weird it is almost impossible to recognize the subject. I kept it.
    barondla
    Feb. 7, 2026, 8:59 p.m.
    Why so many? I was using a 12mm lens on M4/3, so 28mm equivalent. I needed three rows of portrait format, including some that were just sky! Looking back at the original files, it seems I exposed for the sky (it was a fairly dark day if I remember), locked the xposure for all, and then lifted the exposure of the ground in processing. I remember bieng concerned about the movement in the clouds as it took me over three minutes to take all the shots.
    Definitely a fun thing to try, but needs the right locality.
  • Feb. 8, 2026, 6:27 p.m.
    A great idea. I must try it sometime.
  • Members 762 posts
    Feb. 8, 2026, 10:59 p.m.
    Had fisheye lens on my mind. With less wide lens it makes perfect sense. Do you know what went “wrong“ with the first image so the technique can be used again?
    Thanks for the extra info,
    barondla
    Feb. 9, 2026, 9:06 a.m.
    No idea what went wrong really. Maybe not enough overlap, or inconsistent alignment, or bits missing from the series. Nowadays I use Lightroom stitching, but back then it was probably stitched using Microsoft Image Composite Editor, after converting to tiffs.
