• Members 861 posts
    June 16, 2026, 10:01 p.m.
    It’s easy to participate
    Thread Guidelines:
    ”Likes” are encouraged too.
    Experimentation might include, stereo/3D, macro, Infrared, dragged shutter, zone plate, pinhole, motion, fluorescence, multiple exposure, birefringence, ultra violet, optical including adapted lenses, tri color, fractals, manipulated Polaroids, intentional camera movement, pinhole, Kirlian (bioelectrography) and many other methods. Experimentation can be for artistic expression or pure science. It is often more difficult than standard types of photography. This is fine, we aren't expecting perfection. Every experiment enhances knowledge. Your idea can help others explore the universe around them. We love experimentation. You can explain your process or keep it a secret.
    Thanks for viewing and participating,
    barondla
  • Members 861 posts
    June 16, 2026, 10:13 p.m.
    Big Bokeh Bubbles. Pentax K-1 with Pentax 35-70 and Soratama lens. F8 ISO 800 at 20 seconds.
    barondla
    JPG, 239.3 KB, uploaded by barondla on June 16, 2026.
  • Members 478 posts
    June 17, 2026, 8:09 a.m.
    From the world of aphids.
    Forcing the impossible.
    Single frame (from several bursts), image taken in very difficult conditions, namely with wind, variable light and with a microscope lens, on a portion of the plant located 80cm from the ground.
    I will redo the experiment with several devices to stabilize the camera and immobilize the plant. Just for fun.😀
    JPG, 475.4 KB, uploaded by 3DGunner on June 17, 2026.
  • Members 861 posts
    June 18, 2026, 4:49 a.m.
    Isn't wind & movement fun while doing extreme macro? The scale is marked 1mm and the subjects are even smaller. Major magnification like this is very difficult outside a studio/lab. You did a fine job capturing these guys and pushing the equipment to the max.
    barondla
  • Members 2181 posts
    June 19, 2026, 9:42 p.m.
    I’m not sure if this qualifies as photography but it’s definitely experimental. After completing the root fillings on this patient I took a final x-ray. The two fillings I’d finished on each side created an interesting composition with the previous fillings I did. It looked like four gunslingers walking in a western film. I used Photoshop to add skulls instead of gunslingers because it was easier. I might try different things later. There was another x-ray that looked like a ballerina to me. I hope I can find it.
    JPG, 463.2 KB, uploaded by Daneland on June 19, 2026.
  • Members 861 posts
    June 20, 2026, 1:28 a.m.
    Definitely an experimental image. The skulls are graphic and demand attention. The B&W X-ray adds to the creepy and sinister atmosphere. Weird image and I like it
    barondla
