    April 30, 2023, 2:11 a.m.
    If you are worried about the light changing and are too busy to look at the histos, why not just set the ISO a bit lower than you'd normally set it?
    April 30, 2023, 2:13 a.m.
    Yes, I agree the histogram and blinkies (in my case with the 90D) is better, especially shooting raw, but after setting the optimal exposure**, where ISO lands with Auto ISO is not a big deal for me as long as important highlights are not clipped. I set the final image lightness in post.
    April 30, 2023, 2:31 a.m.
    Bolding is mine. If you let the camera set the ISO, you have lost precise control of the relationship of the highlights to clipping.
    April 30, 2023, 2:36 a.m.
    But only if I ignore the histogram is it not?
    I take a shot, look at the histogram and if it doesn't show highlight clipping then the ISO the camera set is largely irrelevant since I have set optimal exposure**, isn't it?
  • Members 811 posts
    April 30, 2023, 2:54 a.m.
    From last night, an out of camera jpeg with a tiny bit of editing resized vs a raw with a trip through Pure raw. Floating ISO. Pretty darn close for simply letting the camera do 90% of the work.P1012363-RW2_DxO_DeepPRIME230429.jpgP1012363230429.jpg
    JPG, 2.3 MB, uploaded by Ghundred on April 30, 2023.
    JPG, 3.2 MB, uploaded by Ghundred on April 30, 2023.
  • Members 811 posts
    April 30, 2023, 3:20 a.m.
    You shot it at 1/100 of a second @ 24mm, and used a flash -the great subject noise eliminator. Odd choice of settings
    [/quote]
    April 30, 2023, 3:38 a.m.
    You can't win much by setting ISO so that the image highlights are close to clipping. However, you can lose big if it's clipped. I thought you were trusting the camera to adjust ISO as the light changes. If you're going to look at the histogram all the time, you might as well change the ISO yourself.
    Why let the camera choose a setting that can't help you much but can hurt you big time?
    April 30, 2023, 3:44 a.m.
    On my 90D I have never seen highlights clipped due to Auto ISO when the camera set ISO above base.
    If anything, in my experience the 90D is over cautious with Auto ISO.
    April 30, 2023, 3:46 a.m.
    I would think that depends on the metering used. Does 90D have only one kind of metering?
    April 30, 2023, 5:20 a.m.
    Then you are saying that regardless of the metering selected, Auto-ISO does not clip highlights. I do not believe that,
    April 30, 2023, 5:43 a.m.
    You are making things up. Post a link to where you claim I said that.
    You asked
    and I replied
    April 30, 2023, 6:27 a.m.
    You said that
    I read your claim that this is regardless of the selected metering.
    If 90D had one metering (a special do-no-clip-highlights-in-Auto-ISO, or a strong highlight-weighted one) then I could believe it ... kind of.
  • April 30, 2023, 8:45 a.m.
    Gents, this is a good subject for a discussion - let's not start accusing people of anything here, please.
    April 30, 2023, 8:48 a.m.
    Then you made an incorrect assumption by assuming I have used all the metering modes. I didn’t mention metering modes at all so if you were in doubt you should have asked instead of assume.
  • Members 53 posts
    April 30, 2023, 11:31 a.m.
    One might set an upper limit on ISO to alert themselves to some other semi-auto guardrail that they have in place and forgot to remove. Like shooting aperture priority with a high minimum shutter speed for a sporting event yesterday. Then today you’re taking indoor pictures and you’re at ISO 20,000 and 1/1,000. Maybe bumping up against the ISO cap gives you a blinking setting reminding you to remove the minimum shutter speed.
    April 30, 2023, 4:33 p.m.
    Which metering mode did you use that does not cause any highlight clipping in Auto-ISO?
  • Members 360 posts
    April 30, 2023, 4:46 p.m.
    It might be silly approach, but it worked for me, kind of...
    I set the upper limit of ISO speed to not get noisy images. With given exposure and given maximum aperture and ISO speed I didn´t get the brightness, the camera reminded me with blinking, that the image is unobtainable by my standards. I either had to add risky shutter speed, or add light, or wait for light, but at the momentary circumstances, things went red and I knew I could spare my battery and efforts.
    It was not the wisest tactics, because now I might miss some photos, which I could delete if I didn´t like them, but oh well, no failed shutters and no biggie. :-)
