• Members 31 posts
    April 12, 2023, 11:05 a.m.
    I have mostly shot landscapes. I take my camera outdoors and shoot what I see. But occasionally I need to take pictures of inanimate objects, tabletop, and I try to use either natural lighting from a window and/or a flash. I'm also a hobby woodworker and like to photograph my woodworking projects when they are complete. I am not satisfied with my results to date taking such pictures, and I feel like inadequate lighting is a large part of my frustration. I basically don't know anything about adapting the light conditions to what I want or need. Beyond a simple flash unit, that I use so rarely that I have to go back to square one each time, I have no lighting equipment.
    So where do I begin? Are there any good sites or books to start with? That would help me understand photographic lighting? The range of equipment - even the terminology is strange to me. I'd like to try using multiple flashes off camera, but I don't even know how they might be supported (stands? mini-tripod?).
    All of my interest is non-professional. I am a retired hobbyist.
    Thanks,
    Peter
  • Members 29 posts
    April 15, 2023, 5:34 a.m.
    A fairly inclusive/comprehensive website that I've found helpful is strobist.blogspot.com. Has three different sections (lighting 101, 102, and 103) that build on each other and are quite helpful. Worth checking out.
    -Matt
  • Members 50 posts
    April 15, 2023, 7:35 a.m.
    You're going for a fascinating journey with a learning curve.
    I'd try to figure out an outdoor place with nice background, shadowed, but with good light first. Even closer to a window might work for you. The next step would be a reflector if the light is too one sided.
  • Members 31 posts
    April 16, 2023, 3:38 p.m.
    Thanks. I'll bookmark that site and check it out.
    Peter
  • Members 31 posts
    April 16, 2023, 3:41 p.m.
    Ah, yes. Another learning curve. I spend too much time reading and not enough time trying.
    Maybe my backyard will do. Lots of trees, and sun when it shines. Once the snow is gone.
    Thanks,
    Peter
    April 16, 2023, 4:14 p.m.
    I learned lighting from the Dean Collins videos. They are old now, but I think they could still be useful.
    Some of them -- maybe all of them -- are available on YouTube.
  • Members 244 posts
    April 16, 2023, 4:30 p.m.
    One suggestion:
    If the still life subjects that you want to take pictures of are fairly small (you said “tabletop”), a good entry point to lighting for you might be using a lightbox/light cube/light shed ….. something like this… it’s also quite large….. there are smaller versions (you can also make your own with some PVC and white nylon fabric):
    www.bhphotovideo.com/c/product/1032648-REG/impact_dls_g_digital_light_shed_36x36x36.html
    Light boxes create amazing product photography images and have the benefit for a beginner of being able to use inexpensive “hot lights” (always on lights …. Even “spot lights” that you can buy at Home Depot or Walmart. Something like this (as a woodworker you probably already have a dozen in the garage):
    www.homedepot.com/p/Woods-60-Watt-6-ft-18-2-SPT-2-Incandescent-Portable-Clamp-Work-Light-with-5-5-in-Reflector-0160/204667690 … do keep the hot light away from the lightbox as you don’t need a fire. Or just get some strong LEDs.
    The light box will act as the diffuser and you can play around with angles, direction, etc. you can also add a reflector inside the box and see what that does.
    Anyway, a good, simple, and inexpensive place to start that will produce good results. Google around the internet for a ton of tips on ‘lightbox photography”….. once you are ready for something “more/different”, it will be time to move to strobes.
  • Members 31 posts
    April 16, 2023, 4:53 p.m.
    Thanks. I think I found him. www.youtube.com/watch?v=ef1ammJiPE0
    That's a bizarre camera he is using. He mounts it on a tripod and then types on the keyboard. I wonder if there is any shaking. There are a couple other videos there as well that I will check out.
    Peter
  • Members 31 posts
    April 16, 2023, 5:23 p.m.
    Thanks. Yes I have seen, and briefly used a lightbox. Our woodturners guild like to post samples of members projects on Facebook and so one guy at our meetings uses a small portable light box and a couple fixed "hot" (?) lights. The one you pointed to is 35 by 35 by 35, maybe just a tad bigger than the one he uses. The lights he uses do not have enough lumens for what I want. My brief use was one meeting he was away and he asked me to handle the photography for him and he lent me his light box. So the little experience I had there let me see what I liked or didn't like about light boxes. They are limited in space so if we had a bigger item or maybe a set of several items (for one picture) the box could become crowded and lighting then suffered a bit. But definitely along the lines of what I was considering.
    An example of one I took, lacking any experience.
    [image.png]
    Thanks,
    Peter
    EDIT: the picture I posted disappeared for some reason that I don't understand.
  • Members 280 posts
    April 16, 2023, 5:32 p.m.
    Light from a large window can be fine, but you do need a reflector to lighten the shadows. A sheet of polystyrene foam works well.
  • Members 140 posts
    April 21, 2023, 5:35 p.m.
    These work great and are a lot of fun. Try one.
  • Members 31 posts
    April 22, 2023, 11:57 a.m.
    Sorry, I don't see anything. What are a lot of fun?
    Peter
  • Members 140 posts
    Aug. 5, 2023, 4:58 p.m.
    I would get one that already have adjustable lights off Amazon.
  • Members 140 posts
    Sept. 7, 2023, 4:12 p.m.
    I call them lighboxes. Search that on Amazon. I like the 36 inch ones.
