• Members 187 posts
    May 25, 2023, 1:20 p.m.
    Please read the description. It can't be 'telephoto' because it wasn't a tele lens (it becomes a 'tele' when we do a heavy crop, simulating an effect of a longer lens).
    Despite being wide angle, does show the compression, yes - you see, at a distance the screwdrivers appear of almost the same size and the apparent distance between them shrinks - unlike the wide angle image #2.
    Again, the ratio of apparent sizes of objects get closer to the ratio of their actual physical sizes, as the camera moves away from the objects. Apparent distance between the objects along the line of sight also shrinks, which makes it harder to estimate the distance.
    It doesn't depend on the viewing distance from the photograph and it doesn't depend on the focal length of the lens.
    So if normal focal length is 43mm, and we shoot at, say, 85mm, the degree of compression is ~2?
    What you're describing is just classic magnification against normal human angle of view. Which was pointed out already in the thread. I'm not sure why you needed to call magnification 'compression'.
    I did it a couple of times already, including this very post.
    May 25, 2023, 1:48 p.m.
    I am sorry, but I do not understand how to apply your 'definition' to other situations.
    For example, suppose you are standing beside a long straight road. There are vehicles 100 yards away, 300 yards away, 400 yards away and 1 mile away. If you take a shot from this position, will it show compression? What about if the vehicles are 1 mile away, 3 miles away, 4 miles away and 10 miles away? What about if the road is empty? What about if you stand in another position?
    I really don't understand when you will see your sort of compression and when not.
  • Members 878 posts
    May 25, 2023, 1:50 p.m.
    A study found out that a typical viewing distance is not normal by your definition.
    May 25, 2023, 2:35 p.m.
    Yes, that's why 'normal' viewing distance is defined. Obviously, you can view from any distance you like. Normal viewing distance gives the correct perspective when viewing a photo taken with normal focal length. See my earlier post with quotes from The Manual of Photography.
  • Members 878 posts
    May 25, 2023, 3:39 p.m.
    Are they really “normal”? My normal viewing distance is determined by the distance my glasses focus, which is the case with many people wearing glasses, I guess. In particular, it is independent of the size of the print unless it is a poster size.
    BTW, religious beliefs can be backed up with quotes as well. I heard that there is a book about that…
  • Members 84 posts
    May 25, 2023, 3:48 p.m.
  • Members 187 posts
    May 26, 2023, 12:14 p.m.
    How do you apply your definition? You described magnification and called it 'compression'. A lens focal length divided by 'normal' focal length is magnification against the field of view from that normal focal length.
    Your definition doesn't provide that either. By your definition, is the image compressed at 44mm? at 46mm? at 49mm?..
    Good example with the cars by the way. When you see other cars at a distance on a hilly highway, sometimes you only see the tops of the cars and you can't discern which car is closer to you. Another simple example - airshow, sometimes you can't tell which plane is closer to you. And you don't need a tele lens or binoculars in order to experience that effect.
  • Members 138 posts
    May 26, 2023, 12:31 p.m.
    I wish I was home so I could post the wide-angle view of the scene I posted above, shot from the same position...
    I found I needed to take a variable out of the consideration of all this for the effect to be understood, and that was position. From a particular position, a scene splayed out in front of a viewer has a particular perspective. You change that perspective when you move around. Nothing else can be used to change perspective.
    Now, from the same position, all a telephoto lens does is to "crop" a part of that scene you'd record with a wider angle lens at the same position.Things look "compressed" because you're looking at an image made from just a small part of the scene.
    This is why "zooming with your feet" doesn't render the same view as actually zooming in with a lens...
    May 27, 2023, 6:23 a.m.
    Congratulations! That is a textbook example of diversionary tactics that people use when they do not wish to admit that they are unable to answer the question.
    May 27, 2023, 7:30 a.m.
    Yes, spot on. "Lens compression" is simply the appearance of background objects being closer to the foreground objects when, from a given position, you zoom in.
    What the others are talking about is how you can move around while using the lens compression effect to create different looking photos.
  • Members 187 posts
    May 27, 2023, 9:42 a.m.
    You ignored my answer or didn't understand it. Also you ignored my questions, is that another textbook example?
    Why do you think the compression has to be either on or off?
    I
    May 27, 2023, 9:58 a.m.
    It's the magnication resulting from zooming in from a given position that causes the lens compression effect. Nothing is physically compressed.
    May 27, 2023, 10:09 a.m.
    I did not see any answer to my question. Instead you asked several questions of your own.
    If someone answers my question by asking a lot of other questions, then I do ignore those questions. They are just trying to divert attention away from my original question (a standard Donald Trump technique).
    It does not have to be either on or off.
    There is a degree of compression, as I said earlier in this thread, which is equal to the focal length divided by the normal focal length (with the usual assumptions). Distances appear to be compressed by that factor. So if you use a focal length that is ten times normal, distances to the viewer (when the image is viewed normally) appear to be one tenth what they were in reality.
    If the focal length divided by the normal focal length is less than one, the picture shows wide-angle distortion instead of telephoto compression (again providing that the picture is viewed normally).
  • Members 187 posts
    May 27, 2023, 10:20 a.m.
    I don't think anybody here claimed something was physically compressed.
  • Members 2411 posts
    May 27, 2023, 10:32 a.m.
    Just dug out my copy of "The Camera" by Ansel Adams, I guess a photographer who was quite strong on theory and a good communicator of theory. Let's look at what he says on page 101 First Edition. I think this is all we need to know.
    "Two photographs made from the same position with two different lenses will be identical in scale and perspective; only the subject area revealed in each will change".
    "Changing to a lens of longer focal length reduces the subject area covered". It may be useful to think of a change in focal length as having the effect of cropping an image".
    Print viewing distance is not mentioned in the "Camera", probably because it is unconnected to the lens focal length effect on a picture. Print viewing distances are a separate subject, that has an added effect. Print viewing distance is out of the photographers control. I may look at a print in an exhibition from different distances.
    May 27, 2023, 10:33 a.m.
    I'm not saying anyone did.
    I'm just making it clear what "lens compression" actually is.
  • Members 187 posts
    May 27, 2023, 10:44 a.m.
    Why bring Donald Trump here? You might as well remember Hitler, as if it makes your point stronger.
    Your questions implied the compression had to be on or off, as if I had to provide criteria for the compression to be present at different distances.
    Most importantly, again, defining 'compression' as 'magnification' > 1 doesn't really work, because magnification doesn't change relative angular sizes of objects.
    Scroll up and take the shot #2 from this post dprevived.com/t/why-is-so-much-nonsense-talked-about-telephoto-compression/3111/post/41180/ and then magnify it. It can be magnified by about a factor of 2 and cropped with both screwdrivers still in the frame. The will be no apparent 'compression'.
    Magnification (that is, optical or digital zooming in) only works because and when you fill the frame with objects that are shot at a long enough distance.
    When you fill the frame with objects that are shot at a short distance, there's no 'compression', with or without the magnification.
    May 27, 2023, 11:08 a.m.
    You're going round in a circle now repeating yourself.
    Your definition of lens compression is different to mine and many others.
    You have made it clear what in your opinion is lens compression and other people have posted theirs.
    I haven't seen anywhere an "official" definition of lens compression and so until there actually is one, all that is going to happen is that people from both sides will just continue going round in circles and turn this into another "megathread" :-D without resolving anything.
