Why would you want rolling shutter in a global shutter sensor?
Dibyendu
April 5, 2024
chat_bubble_outline 8
    Dibyendu
    Members 139 posts
    April 5, 2024, 7:18 p.m. April 5, 2024, 7:18 p.m.
    Nikon applied for a patent:
    patentscope.wipo.int/search/en/detail.jsf?docId=US426729956
    Forum Admin 3906 posts
    April 5, 2024, 7:27 p.m. April 5, 2024, 7:27 p.m.
    Maybe for lower ISO? Or some things that a global shutter isn't good for?
    So the camera will give you a choice.
    tprevatt
    Members 895 posts
    April 5, 2024, 9:27 p.m. April 5, 2024, 9:27 p.m.
    There are multiple reason for filing a patent. I can speak to that as I have somewhere to the North of 50 patents over the years. The one big reason is to put a stake in the ground. That is do sufficient work to determine if a design or technology is feasible and makes sense then protect that IP with a patent. In reality 97% of all patents filed never pay for the cost of the R&D, preparation and filing cost. But it this sensor design turns out to be a good idea - Nikon owns it. Of my 50 plus patents only about 4 have ever been fully implemented. Don't get too excited about patents.
    Diederik likes this.
    Quarkcharmed
    Members 188 posts
    April 6, 2024, 8:26 a.m. April 6, 2024, 8:26 a.m.
    @Dibyendu has written:
    If I get it right, the idea is to balance between 'speed' and 'dynamic range'.
    DonaldB
    Members 2635 posts
    April 6, 2024, 9:53 a.m. April 6, 2024, 9:53 a.m.
    @Quarkcharmed has written:
    its a sensor that can switch from global to rolling readout. best of both worlds.
    Quarkcharmed
    Members 188 posts
    April 6, 2024, 12:01 p.m. April 6, 2024, 12:01 p.m.
    @DonaldB has written:
    Yes it's clear from the description, but what is 'best'? - and their point is to be able to switch between 'speed' and 'dynamic range' depending on the shooting conditions.
    Also they introduce three different operation modes of rolling shutter but I'm lost about the exact benefits of each mode.
    DonaldB
    Members 2635 posts
    April 6, 2024, 9:07 p.m. April 6, 2024, 9:07 p.m.
    cant really answer that as the new canon pro camera has a stacked sensor speed of 1/1250 sec and that will take care of not needing a global shutter.
    StanDisbrow
    Members 699 posts
    April 7, 2024, 12:03 p.m. April 7, 2024, 12:03 p.m.
    I have patents where the corporation I worked for filed them not because they were so much interested in keeping someone else from using the idea as to get extra income when someone else wanted to make use of the idea.
    Or, sometimes not extra income as such, but a swapping of patent licences so they could use someone else's bright idea.
    Stan
    MarshallG
    Members 141 posts
    May 2, 2024, 3 p.m. May 2, 2024, 3 p.m.
    One possible reason is to overcome a limitation of the global shutter operation mode, such as bit depth, so the photographer can choose a 12-bit, fast read electronic shutter mode, or a 14-bit mechanical shutter mode.
