Your favorite adapted projection lenses
simplejoy
May 14, 2023
chat_bubble_outline 15
    simplejoy
    Members 1927 posts
    May 14, 2023, 7:06 a.m. May 14, 2023, 7:06 a.m.
    Until relatively recently, I wasn't the worlds biggest fan of adapting projection lenses. Firstly, because the ones that I had tried were neither particularly unique, nor exceptionally sharp, secondly because of the missing diaphragm and finally because they usually don't feature any mounting thread and therefore need some attention when being adapted.
    However after having some talks with a fellow manual lens fan about the benefits of some projection lenses and seeing some spectacular images by a couple of talented people I decided that it might be worth it to give those optics another try and see if there's something that fits my needs as well.
    I absolutely found a couple of lenses - both from slide as well as cine projectors - and had a lot of fun trying them.
    So I'm very curious to know where other adapted lens people stand on the topic:
    Have you adapted any projection lens? And if so, which one did you like best and why?
    simplejoy
    Members 1927 posts
    May 14, 2023, 7:07 a.m. May 14, 2023, 7:07 a.m.
    I'll start with one I haven't seen mentioned a lot, the Braun Ultralit PL 90 mm f/2.4, an interesting 4 elements Sonnar design.
    live.staticflickr.com/65535/52315388866_af5027d83a_b.jpg
    Ultralit grass
    by simple.joy, on Flickr
    live.staticflickr.com/65535/52315387881_96487f644d_b.jpg
    Cut-the-pillars
    live.staticflickr.com/65535/52315387281_2b1deef9b0_b.jpg
    Feeling punny today?
    I love the rendering of that lens and it provides enough sharpness and detail to work well for a wide variety of applications. I've also used it as a portrait lens - works great for that as well.
    DonCox and Preben like this.
    petrochemist
    Members 208 posts
    May 14, 2023, 9:19 a.m. May 14, 2023, 9:19 a.m.
    My favorite is the first I tried, a russian PO-109-1A 50mm f/1.2
    live.staticflickr.com/4746/38507282230_a100cbbc54_b.jpgProjector lens 1 by Mike Kanssen, on Flickr
    My initial mounting for it (above) proved to have poor focus control (a c### helicoid) so I ended up remounting it into a helicoid brought for the job
    live.staticflickr.com/925/29359189768_6c22301a42_k.jpgMounted 50mm/1.2 projector lens by Mike Kanssen, on Flickr
    live.staticflickr.com/919/42389324115_b85c5dca2e_k.jpg50mm/1.2 projector lens test shot wide open by Mike Kanssen, on Flickr
    The very fast aperture has meant on many occasions it was too bright for the camera, so I sometime add a bokeh mask (cut from black paper)
    live.staticflickr.com/1765/42503059135_d88bd5cc8e_b.jpgjaguar in the flowers by Mike Kanssen, on Flickr
    Preben, JimKasson and simplejoy like this.
    simplejoy
    Members 1927 posts
    May 14, 2023, 7:50 p.m. May 14, 2023, 7:50 p.m.
    @petrochemist has written:
    Great shots and creative use! I assume this particular sample was meant for a smaller format than 35 mm? (Super-16 perhaps?) I think I have a 100 mm f/2 version of that series but not adapted it yet... it's quite heavy and has no mounting thread unfortunately.
    simplejoy
    Members 1927 posts
    May 14, 2023, 7:57 p.m. May 14, 2023, 7:57 p.m.
    Here's a recent favorite of mine, the Meyer Kinon Superior 5 cm f/1.8. My sample certainly won't impress in terms of sharpness, but the rendering is quite worth the drawback in my opinion:
    live.staticflickr.com/65535/52890256114_f8cf0859f9_b.jpg
    Leaning towards chaos
    live.staticflickr.com/65535/52897170085_a517388585_b.jpg
    We‘ll leave and try a second time…
    live.staticflickr.com/65535/52896463929_47c28bf14c_b.jpg
    Happy Mothers Day
    live.staticflickr.com/65535/52779365542_e938d4b646_b.jpg
    Nature needs no open letters…
    Preben, JimKasson and petrochemist like this.
    petrochemist
    Members 208 posts
    May 14, 2023, 9:12 p.m. May 14, 2023, 9:12 p.m.
    @simplejoy has written:
    That is fun. Makes me think I should re-try some that didn't look good on my first quick test. Close up type shots with long focal length projectors might be a bit awkward, extension was becoming clumberson ever focusing to infinity with the Kodak 300mm projector I have
    petrochemist
    Members 208 posts
    May 14, 2023, 9:26 p.m. May 14, 2023, 9:26 p.m.
    Thanks!
    You're right, definitely a smaller format - at infinity it only just covers MFT. It also needs to sit rather close to the sensor I felt it needed a bit of metal trimmed from rear overhangs to prevent it hitting the sensor stack. There was no mounting thread but a step in the outside diameter made the perfect spot to locate a glued on stepping ring - even after trimming the rear it still sticks out the back of the helicoid(IIRC I used one that's 36-90mm 52mm wide at the front & m42 at the back) at it's shortest length (ie. infinity focus) Several of my other projectors can be fitted via the same helicoid :)
    simplejoy likes this.
    simplejoy
    Members 1927 posts
    May 19, 2023, 7:43 p.m. May 19, 2023, 7:43 p.m.
    This is a very nice cine projection lens, the Isco-Optic Ultrastar HD Plus 75 mm f/2.1
    live.staticflickr.com/65535/52549913670_8a05ee56ce_b.jpg
    Cookies - and all worries are melting away...
    live.staticflickr.com/65535/52551415615_041c466fb4_b.jpg
    Robin redbreast? Its story is nuts…
    by ]simple.joy, on Flickr
    live.staticflickr.com/65535/52549276675_aa7b19a50b_b.jpg
    Time to get in shape for Christmas!
    live.staticflickr.com/65535/52894655792_3d1c006b27_b.jpg
    Fur what it‘s worth, I‘m trying to hide
    It's quite sharp and rendering is very smooth. Looks wise it's also one of the most interesting lenses to put in front of your camera, with its shiny red metal. 😅
    Preben likes this.
    simplejoy
    Members 1927 posts
    May 21, 2023, 2:27 p.m. May 21, 2023, 2:27 p.m.
    Because I've seen some great stereoscopic shots by @BosunHiggs I thought I should try with some old captures I took with my next (and penultimate) projection lens, a Schneider Kreuznach Vario-Xenotar 70-120 mm f/3.5 Not sure if it works for you, but it was fun trying it. For me it works best at a distance of around 80 cm to the screen:
    live.staticflickr.com/65535/52912548456_f3708f0922_b.jpg
    Slide and seek
    Here are two regular shots:
    live.staticflickr.com/65535/51985405569_67c7380553_b.jpg
    New life branching out
    live.staticflickr.com/65535/51985673085_dc2f6ab0e8_b.jpg
    Call of color
    I feel like this one is quite sharp for a projection lens with variable aperture and of course more versatile.
    Preben likes this.
    simplejoy
    Members 1927 posts
    July 7, 2023, 4:44 p.m. July 7, 2023, 4:44 p.m.
    Because I've experimented a bit more with projection lenses recently, I also have to mention this one: The Schneider Kreuznach AV-Xenotar 90 mm HFT f/2.4-8 (another slide projection lens with variable aperture). It doesn't have the smoothest rendering at all distances (quite a few Schneider lenses seem to have that problem), but it's quite sharp and versatile and when it works it's great:
    live.staticflickr.com/65535/53028929012_a76eb657a5_b.jpg
    Freedom to grow. Freedom to express yourself.
    live.staticflickr.com/65535/52361916828_232a86c54d_b.jpg
    Under-watering
    live.staticflickr.com/65535/53024386519_45fa41d03f_b.jpg
    Eye know, you see?
    Preben, petrochemist and JimKasson like this.
    PHz
    Members 123 posts
    July 14, 2023, 2:58 p.m. July 14, 2023, 2:58 p.m.
    I have found the revised version of the Leitz Colorplan to be commendably sharp used on the camera (via Heinchens samtfocus device) but it lives on the projector where I prefer it to the Zeiss P-Planar and is usually left there.
    p
    simplejoy
    Members 1927 posts
    July 14, 2023, 6:26 p.m. July 14, 2023, 6:26 p.m.
    @PHz has written:
    p
    Very interesting - thanks for the response! Some of the Colorplans are highly recommended indeed, particularly the Super-Colorplan P2s. Have you tried the P-Planar on a camera as well? I‘ve always wondered about those.
    PHz
    Members 123 posts
    July 17, 2023, 7:10 a.m. July 17, 2023, 7:10 a.m.
    The revised version i mentioned is the one called Supercolorplan P2, while I have not tried the P-Planar on the samtfocus tubes, if time allows I will.
    simplejoy
    Members 1927 posts
    Aug. 10, 2023, 9:35 a.m. Aug. 10, 2023, 9:35 a.m.
    I finally found the smaller brother of one of my favorites, the Braun Ultralit 55 mm f/2.8 and while it's perhaps a bit lacking in terms of sharpness, I found the colors it produced quite impressive. Here's a SOOC shot:
    live.staticflickr.com/65535/53105674942_56371238bc_b.jpg
    Red it where credit is due...
    petrochemist
    Members 208 posts
    March 19, 2024, 12:48 p.m. March 19, 2024, 12:48 p.m.
    I've been playing with a couple of lenses that I think are from rear projection TVs. These have much better coverage than my slide projector lenses, both manage an image circle over 6", making them suitable for my 5x4 monorail (except for the lack of a shutter).
    One is roughly a 150mm f/1.2 that has no manufacturers name or model
    live.staticflickr.com/65535/52632569781_7fc99cff4f_b.jpgA challenging lens by Mike Kanssen, on Flickr
    The other is a 'Delta 77' which gives a FOV of around 120 degrees - It needs to be mounted within the bellows to focus
    live.staticflickr.com/65535/53597640765_f009982b68_b.jpgdelta 77 - deluxe & GG by Mike Kanssen, on Flickr
    I'm not sure I could get the Delta 77 close enough to any of my digital bodies to shoot directly, parts of the lens are well within 1" of the ground glass at infinity focus.
    The monorail might make a good optical bench for checking out more conventional projector lenses, quite a few of them can just be wedged into a 2" pipe lens board :)
    barondla likes this.
    barondla
    Members 676 posts
    March 20, 2024, 4:37 p.m. March 20, 2024, 4:37 p.m.
    That's a big hunk of glass. Doubt it would work on one of those light weight wooden field cameras. Good thing you have a sturdy monorail. Looking forward to some images from this combo.
    Thanks for sharing,
    barondla
