• July 20, 2024, 11:01 a.m.
    Not deleted, moved to the Dumpster - your conversation there can continue if you wish - just people have to opt in to see it.
  • July 20, 2024, 11:02 a.m.
    I think that's a common colloquial use of 'we' rather than attempting to speak on everyone's behalf.
  • July 20, 2024, 11:24 a.m.
    What we're dealing with here is not some unquantifiable vagary of human perception. The mathematics of perspective have been known since the 15th century and has become its own branch (en.wikipedia.org/wiki/Perspective_(geometry)).
    The conception that perspective applies exclusively to objects in 3D space seems to have occurred to photographers, who seem not to have done much research into the history of perspective in art, and jumped to the conclusion that because it is 'in art' it's somehow not rigorous or mathematical.
  • Members 358 posts
    July 20, 2024, 12:09 p.m.
    But that doesn't prove that the world that our cognitive function presents us with is an exact match to linear geometry.
    I can only speak for myself and my research into the history of art and perspective. Correct perspective is visible in graeco/roman art, but per object. There is no unified linear perspective. That came with the Renaissance and was: Linear; separation of planes; atmospheric; and classical colour theory. If we only stick with linear perspective we find that although limited in viewpoint it was absolutely derived by rigorous and correct maths (barring the visits from the Inquisition). But what is left out of these discussions is that even before Leonardo it was widely understood that it always looked slightly odd, or different to the way we see the actual 3D world. It was well understood that it depended a lot on viewing distance to the point that the practical understanding was that when viewing images people never really saw linear perspective correctly, it always looked slightly distorted.
    But the Renaissance was the era of science and so artists spent a lot of time trying to get around this by both modifying the mathematical model, or deriving more empirical ways of defining it (the movement of hand and eye) such as lengths of string through a fixed hole.
    If we want to look at the history of perspective in art then we need to look at all of it, these discussions tend to be selective.
  • July 20, 2024, 12:53 p.m.
    True, but the acceptance over a very long period of time suggests that it is close. You can say exactly the same of 'colour science' which has looser links to actual human perception. Plus of course, human not all being identical there is a spread over the population, and we are talking about norms or means, not every one of us.
    Agreed also - but we also need to take the context of this particular discussion into account. There is a line common in photographic circles that 'perspective' depends only on camera-subject distance. I suspect that this is the context for Tom's OP, which was intended as a rhetorical rebuttal of that view. The point in the end about that is those putting forward that point of view are correct within their own definition of 'perspective', but that definition is different from the 'artistic' or mathematical one. Thus it's a semantic question.
  • Members 358 posts
    July 20, 2024, 4:08 p.m.
    Tom has often said that he is only discussing the retinal image. In this context there is no problem with semantics. But “if” the assumption is that because the angle subtended on our retina pre cognitive function is the relevant data for the conclusions we must arrive at through cognitive function… Then we must be making one hell of an assumption about how the brain collects processes the data. What if that explanation isn’t even close?
    The height of a known object subtends an angle and so if you magnify it and it subtends a different angle then this affects our interpretation of height and that defines how we must interpret the relative distances… Why do we only consider one dimension when there is a lot of other information that is relevant to the correct mathematical perspective in the image?
    Are you sure that wouldn’t require us to program the machine to follow that logic?
    ”If” t-c can only be explained by including an element of cognitive function that explains why we make an error of judgement, (why we disregard some information in favor of other), then are we also aware that explanation we are pursuing specifically excludes that possibility? Just sayin’.
  • July 20, 2024, 4:30 p.m.
    The discussion has become far too convoluted to trace down exactly who said what and precisely what they meant. There are a number of ways of interpreting the 'retinal image', so there still is a problem with semantics - just apart from the fact that all kinds of geometric corrections are made by the visual cortex to the image projected onto the retina. It is after all a (rough) spheroid with an optically not-very-good lens on it. It seems to me that there are two issues at stake here - geometry and interpretation. We know from all number of optical illusions that the same geometry can support a number of interpretations. So let's split this into two. The artist's mathematical formulation of perspective is about the geometry of a 2-D picture that will support its interpretation as a 3-D scene. That formulation applies whether that picture has been created by a human artist, a computer program or a camera. Taking just the latter, a separate (but related) concern is the optical geometry by which such a picture may be created by a camera.
  • Members 358 posts
    July 20, 2024, 5:02 p.m.
    I am only talking about one issue, that we keep trying to explain the latter, interpretation, which includes cognative function, through an understanding of geometry. We keep mixing the two, we keep using visul example as ptroof of geometric fact without allowing for the nature of cognitive function. We use the eye to see a valid point and do bot consider whether we've introduced part of the error we try to explain with the maths.
    The proven truth is it is not just the geometry, cognative function actively alters the data. This is key, this is what your outlook and the conclusions you seek prohibit. Even you can't see beyond the geometry as a complete and full explanation. That is what is wrong here.
  • July 20, 2024, 7:45 p.m.
    I think that the success of linear perspective in art for over five centuries suggests that this geometric model of interpretation works rather well. As I alluded to, we don't seem to argue about 'colour science' where we model 'interpretation' (or cognition) with mathematics, and that has a much shorter history. To be clear, the geometry is not the cognitive process but it models it.
    I suspect you didn't get my point here about the two separate things. Classical linear perspective is not cognition, but it does model the cognitive functions associated with depth perception very well (in the same way that CIE models colour perception). That is a different thing from the geometric optics which models the process by which the image of a set of objects in a 3-D space can be projected onto a 2-D plane, even though a great deal of the geometry is common to both.
  • Members 358 posts
    July 20, 2024, 10:13 p.m.
    Didn't I say that very thing a page ago? The part I have a problem with is Tom's conclusion that t-c is a mathematical truth in the image explained by the image geometry, and so is predicted by the image geometry:
    And doesn't answer my main objection (though a bit of a keyboard mash):
    I don't know enough about the maths of colour theory, but I'm pretty sure we don't use the physics of light without taking into account cognitive function. Linear geometry explains the mapping of a 3D scene perfectly, and our perception well enough to be used as a solid example. But we have to recognise the limits.
    Say you are a stone age man (I know your not because like me you don't have enough hair) standing in a field, spear in right hand, scratching ass with left, when a tiger jumps out of the hedgerow. What do you do, reassign the task of your left hand or have a discussion with yourself about phenomenology? It may sound daft, but consider if Darwin is correct then which course of action is most likely to promote your survival long enough to be discussing this on an internet forum 6000 years later; developing absolute vision or being able to trust that vision is absolute and act instinctively on it? Optical illusion shows us that it's the latter, the brain actively works to present a consistent understanding over an absolute one. And it's this that holds the key to why we make the initial (wrong) assumption about distance in t-c images. It isn't a mathematical function of the image. And so even the Adams fallacy falls flat (he was just trying to give an easy visual key) because the assumptions of the maths are flawed when we don't consider that perhaps the reason we don't see some images correctly is highlighting the slight differences between cognitive function and linear geometry rather than trying to make them confirm the maths.
    I think it's still a very valid point. I do understand yours and within the points outlined above pretty much agree. Nice talkin'.
    July 21, 2024, 8:10 a.m.
    Andrew, I suggest you start a new thread to give your explanation of telephoto compression in detail.
    I think you have said that you agree with the science and mathematics of perspective. My own ideas are based entirely on the science and mathematics of perspective established over the past 500 years or so. I have added nothing to the accepted theory of perspective. Yet you strongly disagree with almost anything I say about perspective. I'm puzzled.
    I think it is time you started your own thread to give your view of telephoto compression and related topics in perspective. How do you explain telephoto compression? It would be much more constructive than simply attacking my threads on the subject in a purely destructive and often highly offensive manner.
  • July 21, 2024, 10:08 a.m.
    As a bystander, I see this as a case of six of one and half a dozen of the other. You have both been attacking each other for weeks now. It is a most unedifying spectacle and unworthy of the noble aspirations of this forum. Please desist. 😀
    July 21, 2024, 11:02 a.m.
    Please forgive me David, but I don't understand why you feel compelled to continue reading and contributing to a thread that you find "unedifying"? There are plenty of threads that I do not like for one reason or another, but I do not read them (beyond the title and sometimes the first post or two) and I certainly do not contribute to them.
  • July 21, 2024, 1:39 p.m.
    You possibly dis say it, but this discussion is o convoluted that it's hard to be certain about who said what or what they are actually arguing about. It's very common for people to think that mathematical models represent ground truth, so I wouldn't get to worried about that. It's a philosophical point.
    I'm not sure that I fully understand what you main objection is.
    We take the physics of light (as in wavelengths) and feed that through another mathematical model which represents cognitive function. The model works well enough that it's only really questioned in research papers which point out that it could be a bit better.
    Yes, it is nice talking so long as people don't take their disagreements too seriously.
